Slightly beginnery questions here, but this is confusing me. I've bought a cube ams frame and a fox rp23 shock and I'm keen to get them bolted together! The shock is from here http://www.chainreactioncycles.com/fox-suspension-float-rp23-rear-shock-2012/rp-prod82842
It has what look to me to be 'top hat' reducers on the top and nothing on the bottom as in the photo. I realise that I need to get the width right, but what are the actual parts I need, du bushings? Another set of top hats? I know about tf tuned but I was hoping to pay less that 30 quid as this project is already getting out of hand. Any help would be much appreciated!
this should help ... http://www.tftunedshox.com/MountKitGuide.aspx
not sure you will get them cheaper though...
Thanks for the reply, is that for the shaft end? As far as I can see, I already have the reducers on the body end, is it just a case of du bushings for that, or have I got the wrong end of the stick entirely?
that guide tells you what you need for both ends, as far as im aware theres usually reducers both ends.
if you have the mount kit then you just need du bush in eyelet
