Cannondale advice n...
[Closed] Cannondale advice needed, please
[#5581158]
How difficult is it to fit an Opi stem/steerer to the bike? I want to get a much lower position on the bike than the current set-up.
Thanks,
matt
Posted : 07/10/2013 7:48 pm
easy, very easy, less that 5 minute job. What do you currently have and what are you trying to acheive. I have two OPI stems both 100mm, one is -5 rise the other -15 rise. Both for sale.
Posted : 07/10/2013 7:51 pm
hello, that was quick. I have a 2011 alloy flash with an OPI compatible stem Lefty but the stem set-up is too high for me. A -15degree rise at 100mm would be perfect but how do you go about fitting it? The Opi specific steerer replaces the old one and then is it just a matter of tightening the stem down onto the threaded steerer with an old old shimano bb tool- the same one that tightens the cap on the top of the Lefty?
Cheers,
Matt
Posted : 07/10/2013 7:56 pm
 DanW
Page 12 and 13 of this [url= http://media.cannondale.com/media/Manuals/2012_Lefty_OMS_126564_0811.pdf ]PDF[/url] has everything you should need.
I am waiting on my Lefty to install one for the first time myself but it really doesn't look tricky at all. Torque wrench and a Shimano BB tool looks to be the only tools needed...
Posted : 07/10/2013 8:00 pm
 DanW
I also found this diagram nice in illustrating the effect of different OPI stems. Bear in mind that a -15 degree stem will change the saddle to bar distance (reach), more so than the diagram perhaps suggests since the steerer is not perpendicular to the floor but instead angled. It shouldn't be too noticeable but the diagram is nice in showing how varied the bar position can be with different stems
Posted : 07/10/2013 8:16 pm
Cheers Dan,
That is really useful! I still don't trust myself but will give it a go first and if I fail I'll take it to my local shop.
Thanks again.
Matt
Posted : 07/10/2013 8:43 pm
