Rear shock loosing ...
[Closed] Rear shock loosing air
[#6237721]
On today's ride my rear shock seemed to keep loosing the air I put in it. I pumped it 3 or 4 times and after about 5 mins it was all gone again.
Will this likely be a simple issue or a bike shop jobby?
On another note I managed to kneel in a red Ants nest and boy are those little buggers fiesty.... Ouch
Posted : 01/06/2014 1:57 pm
Sometimes just the valve core coming loose, tried tightening it?
Posted : 01/06/2014 2:04 pm
Dunk it in a bucket of water, or spray with soapy water to see where it's bubbling from.
Posted : 01/06/2014 2:07 pm
As above the valve core is worth checking but if the air is escaping from the main shaft seal, new seals might just be all you need & are easy to replace.
Assuming it's not new(ish), a full service would probably be in order, if the seals have had time to break down.
Posted : 01/06/2014 2:30 pm
It's a 2011 camber which I bough 2nd last year. To be fair it's due a service.
It is my first full sus so I have no idea as to the mechanics of shocks.
When I put air in the first time the valve was a tad loose, maybe I didn't tighten it up enough.
It's fully safe to submerge it in water then?
Posted : 01/06/2014 7:34 pm
I had similar with my Maverick shock. It was a slower leak than yours but I put it off for ages and kept topping it up. I eventually sent it off and it came back working like a brand new shock and it changed the feel of the bike. Don't put it off, get it serviced.
Posted : 01/06/2014 8:07 pm
