I've just bought a bike and when you pick the rear end up there is some movement before the wheel comes off the ground. My question is, is it the du bushes need replacing or what? Any help would be great. Rob
Posted : 11/03/2013 9:11 pm
Sounds like it.Thats the usual sign..
Posted : 11/03/2013 9:15 pm
yep. easy job to do yourself
Posted : 11/03/2013 9:16 pm
There isn't any sideways movement so do you think the actual bearings will be ok?
Posted : 11/03/2013 9:17 pm
Take the shock completely out and remove the rear wheel.Run the frame through it,s travel and also check side to side.You'll feel if anything is a miss. ๐
Posted : 11/03/2013 9:23 pm
Cool, thanks for the help. ๐
What's the difference between DP and DU bushes?
Posted : 11/03/2013 9:53 pm
