Sorry to ask, but the page I want on the Shimano website is blank
I have a 38:24 chainset and 11:36 10 speed cassette
Can I get away with a medium cage or do I need a long cage? Rigid frame. XT M781 mech
Ta
with a 38t front and 11-36 on the rear a medium cage mech might be a bit of a stretch because of the ratios involved so you might be better off with a long cage, however the zee rear mech (fr version) does apparently run up to 36t so you might get away with it
i'm happy to be corrected if i'm wrong on this
I had 42-28 on the front and 11-36 on the rear before going 1x10 and a medium cage X9 worked fine. Not sure if SRAM sizings are different to Shimano - I would have through medium would do, given it's a hardtail.
Thanks folks. Medium ordered
