rear mech 1x10 comp...
[Closed] rear mech 1x10 compatability
[#4825363]
Evening, bought a short cage type 2 x9 10 speed rear mech. Running an 11-36 on the rear 34t on the front. Now all writing I have seen on the mech say its compatible with a 36t ring. Although when I installed it it wouldnt go up to the 36t at the back. The cage was almost parallel to the ground. Is this because I measured the chain wrong? Measured using front ring round big ring at back not through mech.
Any advice?
Posted : 01/02/2013 10:33 pm
Did you add 2 links to this? If not, your chain is too short.
Posted : 01/02/2013 10:39 pm
Definitely sounds like the chain is too short
Thank god for that. No I didnt what a idiot.
Screwed the chain putting links back in, bent the plate on the other side! Grrrrr
Posted : 01/02/2013 10:45 pm
