Great service from ...
[Closed] Great service from LBS & Hope
[#4825367]
Popped into LBS with a wheel to be trued and just got chatting, mentioned that I'd noticed a crack in one of the disc mounts but wasn't to worried. Was told that it might get warrantied and had I called Hope. Left it with LBS and got a call 2 hrs later to say that Hope will in fact warranty the hub and it'll be a Pro 2 Evo
Result 😀
LBS - Cycle Centre Congleton
Posted : 01/02/2013 10:42 pm
Hope have always been great for me, even when items have been out of warranty.
Posted : 01/02/2013 11:04 pm
Agreed, they fixed my cracked out of warranty freehub for free. It's clearly made a good impression, I've just bought a new set of Hope wheels 😳
Posted : 01/02/2013 11:05 pm
I've had many good experiences with Hope. But the only warranty issue was a battery that wouldn't charge. one short phone call to explain, right away was told 'we'll send you a returns envelope and form. If we can fix it we will. If we can't fix it we'll send you a new one.'
they did just that, no asking how old it was, or where it was bought from, or to see a receipt - just got the impression they wanted to make it right. spot on!
since then I have a set of V-twins, three headsets, two bottom brackets, a set of pro 3 hoops and two sets of pro 2 hoops. And an R4 light which I won in their facebook comp!
I should point out that those components are on different bikes and not replacements!
Posted : 01/02/2013 11:33 pm
Aye hope are ace, as is mongleton cycle centre! One seal failed on my m4 caliper - came back 2days later all new seals, pistons, pads & hose even though I'd lost my receipt & they were out of warranty. Same with cracked freehub & axle.
Posted : 01/02/2013 11:43 pm
