Hey dudes, yeserday my mate tried to set my rear shock up and found that therer was no preasure and when he tried to put air in it wouldnt hold any psi..
The funny thing is that the shock is still has bounce and travel init. I would have thought with no preasure it would just be bottomed out (its at the top )
What do I need to do? Seal kit??
Dip it in a bucket of water to see where the air's escaping first, it may just be a leaking valve core.
Ahh right.. and is that an easier fix??
If it is the valve, see your local tyre fitter or LBS, who can unscrew it with a valve key, and pop a new one in. Probably cost a couple of quid at most. If it's a seal problem, it's a little more involved, but easily within the scope of home mechanics, check Fox/Mojo's site for info on servicing.
