Rear bike light die...
[Closed] Rear bike light dies in sub-zero temps.
[#2305508]
I have a Smart Lunar rear light, which is a great piece of kit and very bright. However the light dies to a vague glow when it gets cold (sub zero), but is then fine when back in the house. Is this due to a poor choice of battery (Energiser Industrial Alkaline - AAA), or is there something wrong with the unit?
Posted : 22/12/2010 12:17 pm
 aP
Probably because the batteries are nearly done. Put new ones in and try it.
Posted : 22/12/2010 12:24 pm
 cp
Yep, most high power LED's work best with NiMh rechargables as they are better in high-drain applications (less internal resistance or something). At room temp you prob wont notice much difference on a rear LED, but make things very cold and that will change.
Try with rechargeables.
Posted : 22/12/2010 12:37 pm
Cheers guys, the batteries are brand new, so I don't think it's as simple as changing them, I'll give some re-chargables a go. I've also just read that Lithiums are better in the cold.
Posted : 22/12/2010 1:10 pm
