zesty with a 36 for...
[Closed] zesty with a 36 fork?
[#2305496]
morning all, anybody got a 36 on a zesty and how does it ride?
the floats can be knocked down in 10mm increments i believe so it could be set to 150 or even 140 if necessary.
Posted : 22/12/2010 12:09 pm
Yeah mate, I tried mine with a 36 Talas for quite a while.
I thought it was too long for anything except very steep stuff on 160mm.
And 130mm setting was alright for normal riding, but not quite as good as the 150mm fork I usually have on there (set at 145mm on the U-turn).
Reducing the travel on the 36 by 20mm might be a good move.
Posted : 22/12/2010 12:22 pm
cheers i thought as much, im not really after the extra travel, just the 20mm axle and stiffiness anyways.
Posted : 22/12/2010 12:28 pm
actually, chakapig, don't suppose you've swapped off any of the lapierre branded parts have you?
wondering if you weighed them?
cheers
Posted : 22/12/2010 12:37 pm
yes I took them off but not weighed them
stem and bars were light-ish, on par with say Easton ea50 or RF Evolve
seatpost bit heavier than average, good quality though - never budged when on
Posted : 22/12/2010 12:40 pm
great stuff thanks,
Posted : 22/12/2010 12:49 pm
I don't think i'd run a 36 on the front of mine, far too much unnecessary bulk.
I'm running a set of 150mm Revelation Teams on mine & it feels just about bang on 🙂
Posted : 22/12/2010 1:25 pm
 dlr
Yep, some 160 Devilles, they replaced the 150mm 32's I had which in turn had replaced the original 140's. Yes up steep climbs its a bit worse especially as I only have a float R so cant prop the rear up but I still cope and get up most stuff, 50mm stem as well but thats been on there a long time. The minor extra weight is worth it for the reduction in twang compared to flexy fox 32's (not tried recent revs so cant compare but I know some ancient 20mm Pikes I have are far less flexy than 32's)
Posted : 22/12/2010 4:37 pm
thanks dlr, currently using some ancient 20mm pikes too and not too willing to go for a 32 with 15mm, but willing to be proved wrong on a test ride. i weigh about 17 stone in riding gear so it's going to be obvious i think, my old qr floats were everso bendy
Posted : 22/12/2010 8:16 pm
I'd go with Revelations meself, not as stiff as a 36 obviously but not what I'd call flexy either, and stiffer than the 150mm 32 as long as you get the maxle one. Great bits of kit.
Posted : 22/12/2010 9:04 pm
"Reducing the travel on the 36 by 20mm might be a good move"
I'd go with reducing by 30mm, to get it the same height as a Fox 32 140mm QR15
Posted : 22/12/2010 9:07 pm
good point James, will investigate max warranted A to C, not just travel
Posted : 24/12/2010 10:53 am
