My nephew's Saracen Raw 2 has a snapped rear axle spindle - a common problem apparently. Any one know where I can get a replacement?
Posted : 24/04/2011 5:20 pm
What hub is it?
Posted : 24/04/2011 5:45 pm
Guessing it's a screw-on freewheel type hub(main bearing sits on the unsupported middle section of the axle), if so then most bike shops will have a replacement.May be worth upgrading to a freehub type system when the drivetrain needs replacing.
Posted : 24/04/2011 6:56 pm
It's a no name hub- assume it's the one that comes with the bike so cheap!
Bearings are loose inside the hub, so may well be an easy fix - will take it to LBS and see.
Posted : 25/04/2011 8:54 am
