used these on a road ride today, the last 45 mins was on wet road, feet got soaked,
owned for 12 months, have experienced wet feet before but only when going over ankle deep in a puddle, so water seeps through the ankle collar to the feet, fair enough, but today was coming in everywhere
is it possible to re-waterproof them? any products on the market? or could I claim they are faulty?
these were my fav product of the last 12 months, no hassle with seal skins and overshoes, but today they just performed like an average non mesh vented shoe
I use dubbin, not only waterproofs them but keeps them soft and supple
You could treat the surface to stop the material wetting out. However, if they are letting water in, then the gore tex "sock" in the shoes isn't doing what it's supposed to. You could test them by filling them with water, sitting them in the bath and see if it leaks out. They could probably do with a good rinse now anyway.
Worried about this now as I've just bought a pair.
They are gore-tex non? If they are wetting out through the membrane then the membrane is f00ked, arguably faulty in that case.
Are you sure that the water was not just running down your legs into the boots? It sounds as if the water would have been spraying onto your legs from your front tyre.
Grim
