"Raw" fin...
[Closed] "Raw" finish frames - anyone done a diy job
[#864033]
Just wondering if anyone has had a go at stripping back a powdercoated frame to get a raw finish? If you have any pictures and tips would be good to see. I presume that you use some lacquer after the strip back to protect the metal.
Thanks
Rio
Posted : 13/09/2009 8:12 pm
Havent done it on a MTB frame but did do it on a motorbike frame and the coating was a bitch to shift I regretted starting after about 10 minutes but it was too late by then. My opinion dont bother powdercoat is tough
Posted : 13/09/2009 8:24 pm
I did mine - stripped the paint with nitromors and a wire brush and polished it with 3M polishing pads. Came up a treat.
It is ti though, if you are doing this to ali the wire brush may have to be avoided. I guess a clear lacquer would be needed to ptotect from corosion too.
Posted : 13/09/2009 8:57 pm
If you do a steel or ali frame by hand at home, the corrosion will have set in before you get the whole thing finished. The best way would be to take it to a metal finishers and they could chemical dip it and laquer it before it corrodes and before anyone says it, aluminium does corrode.
Posted : 13/09/2009 9:05 pm
40mpg - Member
40 mpg powder coat isnt paint its polyester plastic I think. Nitromors doesnt touch it or at least diidnt touch the powder coat I stripped.
Posted : 13/09/2009 9:08 pm
Oh. It was an on-one so the paint blows off in the wind anyway.
Posted : 13/09/2009 9:22 pm
My mates 456 looked like it had been painted with matt emulsion only it wasnt quite as good a finish
Posted : 13/09/2009 9:25 pm
Posted : 13/09/2009 9:26 pm
? delayed reaction!
Cheers, it is alu so I think I'll try and find somewhere that can dip it and lacquer it for me
Posted : 13/09/2009 9:29 pm
"Raw" is usually that, raw, left to oxidise. But if you want to maintain a shiny finish it needs lacquered.
[url= http://www.irishdh.com/index.php/news-mainmenu-2/17-riders-bikes/60-michael-cowans-intense-m6 ]CRC's Michael Cowan's M6, for example.[/url]
Posted : 13/09/2009 10:06 pm
Look up chemical stripping on yell.com
An acid bath will strip it in no time, & cost you about £10-£15.
Dont go expecting Lynskey / Van Nicholas levels of beauty afterwards though, at least not without lots of hard work.
Posted : 13/09/2009 10:48 pm
