Raceface ISIS BB in...
[Closed] Raceface ISIS BB installation help
Hi,
I'm trying to install a RF Signature ISIS ti BB which I understand should fit both 68 and 73mm BB's - I'm trying to get it into a 68 shell and it keeps going tight with still a few mm's of the cups sticking out on each side.
Does anyone know how you adjust it to fit a 68 ? - I've just replaced the bearings which are now snug but without the proper tool were a bit tricky to get installed.
Any help from the STW collective much appreciated
Posted : 12/09/2009 3:55 pm
are you using the 2.5mm spacer?
Posted : 12/09/2009 4:01 pm
err not sure - there was just the black plastic in the middle and then the bearings are up flush against the ridges on the axel - where would the spacer go ??
Posted : 12/09/2009 4:26 pm
if you fit it to a 68 mm shell, a bit of the cup pokes out either side. If you fit it to a 73mm shell, the cups recess a few mm either side.
There are no spacers, there are no fixed cups (ones with flanges on) which is how you can fine tune the chainline on it.
Posted : 12/09/2009 5:01 pm
Sorry, Onzadogs right, I was talking about regular fixed cup RF isis... so... i guess your install is correct as you have it.
Posted : 12/09/2009 5:28 pm
Onzadog - thanks I'd just sort of come to that conclusion myself - reinstalled with about 2mm sticking out either side - sort of looks OK I guess - thanks for all the replies.
๐Ÿ˜€
Posted : 12/09/2009 6:06 pm
