Race Face Turbine C...
[Closed] Race Face Turbine Crank Removal
Can someone tell me how to remove this crank - http://www.cyclesolutions.co.uk/p60946/race-face-turbine-cranks-10-speed-104-64-double-ringset
Do I only need an 8mm allen key for this job?
Posted : 23/04/2014 1:09 pm
Yup! The inner 8mm head bolt pushes against the outer cap as you undo it.. extracting the crank as it goes.
Posted : 23/04/2014 1:12 pm
[url= http://www.parktool.com/blog/repair-help/external-bearing-crank-systems-hollowtech-ii-megaexo-giga-x-pipe-x-type-campagnolo-ultra-torque ]http://www.parktool.com/blog/repair-help/external-bearing-crank-systems-hollowtech-ii-megaexo-giga-x-pipe-x-type-campagnolo-ultra-torque[/url]
basically, yes, but details above.
Posted : 23/04/2014 1:13 pm
the 8mm cap only loosens a bit then rubs off the 10mm bolt so I can't loosen it anymore. Am I being stupid here?
Posted : 23/04/2014 1:16 pm
[i]The X-type right side crank has a one-key release system. The retaining cap use a left-hand thread, and is secured to the arm with a 10mm hex wrench. It is not necessary to remove the one-key system. To remove the arm, use a 8mm hex wrench on the crank bolt and turn counter-clockwise. One-key system will remove arm from the spindle. After removing the right arm, pull the left arm to remove. It may be necessary to use a mallet and tap spindle to free the arm.[/i]
basicaly the bit it's rubbing on acts as a self extractor for the crank if you keep turning the 8mm bolt.
Posted : 23/04/2014 1:18 pm
Keep unwinding against the 10mm cap. It'll budge eventually
Posted : 23/04/2014 1:19 pm
Just keep unscrewing it, it is meant to unscrew against the 10mm bolt essentially pushing the drive side crank of with each unscrew of the 8mm bolt.
