Hi do I need an extractor to remove a race face crank or should the right hand crank come out, with a gentle tap (hammer) once the 8mm bolt has been removed?
Thanks in advance
Posted : 06/09/2015 10:36 pm
Which crank? Crank extractor for the modern ones, I think the older ones had some kind of self extracting job on there.
Posted : 06/09/2015 11:14 pm
Ride needs an ISIS extractor iirc.
Posted : 07/09/2015 5:39 am
Hi nick warp cow. It is ride so I'll look one tube and try and gauge how likely it is that I can do the job or do go to lbs?
Posted : 07/09/2015 9:19 pm
That was meant to Say " look on u tube"
Posted : 07/09/2015 9:21 pm
Yes you'll need a crank puller-about the only one still on modern bikes that do!
