race face crank rem...
[Closed] race face crank removal
[#6222852]
I've got race face evolve xc cranks. To remove the drive side you are supposed to use a puller e.g. park ccp-44. I dug around in the garage and found an old tool from waaaay back over ten years ago when I last had an ISIS BB and found park cp-4. Thing is the cranks did not budge that easily. Is it a case of:
More power required
or
They have sneakily changed the 'standard' and I'm going to strip the crank threads
Posted : 27/05/2014 9:56 am
You sure it's supposed to need a puller? Mine has a self-extracting bolt
Posted : 27/05/2014 10:08 am
Aren't all raceface cranks the same?
Leave the 10mm top cap alone, and use an 8mm allen key?
Posted : 27/05/2014 10:09 am
it is not a self extracting bolt
Posted : 27/05/2014 10:14 am
 JoeG
Make sure that there wasn't a washer under the crank bolt head which stayed in place.
Posted : 27/05/2014 3:12 pm
