Quick question abou...
[Closed] Quick question about Shimano hydraulic brakes
Are the hose end and 'olive' assembly supposed to be sealed against an o-ring in the housing? I can't see any o-rings now that I've disassembled everything; coming from an engineering background I would expect to see o-rings.
Posted : 11/02/2022 9:49 am
No need. That's what the olive is for.
Posted : 11/02/2022 9:54 am
Good to know thanks.
Posted : 11/02/2022 10:01 am
Nope.
Why? a well executed olive type joint (as above) doesn't need any additional sealing.
Posted : 11/02/2022 10:47 am
Olive seals onto the hose (insert prevents crush), olive also seals onto both tapers
Posted : 11/02/2022 12:31 pm
WHat sort of working pressure does a brake hose see do you think?
Posted : 11/02/2022 12:45 pm
....must be a software 'engineer'!
Posted : 11/02/2022 1:19 pm
Probably either: 1) Eek, 2) Ooff or 3) Fuuuuuuuuuuuuuuucckkk
Posted : 11/02/2022 7:57 pm
Posted : 11/02/2022 8:58 pm
