Quick headset quest...
[Closed] Quick headset question!
Morning!
Just got a new frame and it's got a 44mm headtube. I've got 1 1/8 forks already but may also get tapered forks in the future. Looking at Hope pick n mix headsets. Will an "H" model do the job so I can swap out 1 1/8 and tapered forks? Going for a "No.2" model for top. Do I need anything else?
Thanks.
Posted : 24/09/2015 7:37 am
Yup 2 top and B lower for 1.125" straight steerer and swap the lower for an H when you get tapered forks
Easy job done it meself nothing else required
Worth spending some time getting the spacers on the top cup just right and lining up the logos
Posted : 24/09/2015 7:45 am
Thanks. Another question. Can I use a"H" Hope bottom cup and a crown race reducer for the 1 1/8 forks so I can swap them out to tapered with out changing the bottom cup?
Posted : 24/09/2015 10:34 am
Yes, use the reducer, works great.
Posted : 24/09/2015 10:42 am
Yup sure. Not Hopes though IIRC it's for 1.125" steerers in 55/56 mm head tubes
Worth checking though info@hopetech.com they are very good
Thanks pips. Headset ordered!
Posted : 24/09/2015 11:24 am
rocketman - Member
The Hope reducer crown thingy adapts a 1 1/8 steerer to a 1.5, so it fits a tapered headset - your headset sits on top, that's what adapts to the 44/49/56/whatever head tube - I've used them in 44, 49 and 56 hope headsets, no problems at all.
Posted : 24/09/2015 12:34 pm
Ok thanks!
Posted : 24/09/2015 1:12 pm
