Quick headset help ...
[Closed] Quick headset help please
Afternoon all, planning to get a set of the On-One tapered rigid forks to play around with in the winter weather over here.
I've got a standard sized forks today with an adaptor so clearly I'll need, at least, the bottom half of a new headset. Therefore is it the Smoothie Mixer Tapered headset I need?.
Thanks.
Posted : 25/11/2012 1:02 pm
I would stick with your upper part of your existing headset and just replace the lower part with one of hopes pick and mix ones . Hope that makes sense .
Posted : 25/11/2012 2:38 pm
OK, so just the crown race then?. Thanks
Posted : 25/11/2012 3:37 pm
I assume you have a 1.5" headset already and your using adapters to fit 1 1/8 steerer if so then yes you should just need a crown race.
Posted : 25/11/2012 8:01 pm
