question for squirt...
[Closed] question for squirters and others wax lubers
[#4019037]
so when your chain and cassette get a bit grimy and sticky after half a dozen rides with Squirt or other wax lube (road bike) do you fully degrease and if so how, before reapplying, or just squirt some more one ?
Posted : 29/05/2012 6:39 pm
Squirt on squirt Goethe chain. Anything on the cassette or rings comes off with a baby wipe.
I use putoline wax and clean the excess off with baby wipes after the first ride on a newly waxed chain.
Posted : 29/05/2012 7:07 pm
I came in here expecting, well. You know.
Posted : 29/05/2012 7:13 pm
Posted : 29/05/2012 7:33 pm
Not noticed a problem on the MTB, I assume the mud cleans it off for me 🙂
Posted : 29/05/2012 8:06 pm
tried the baby wipes - top job 🙂
Posted : 30/05/2012 12:46 pm
Cleaning?
If I had time to clean my bikes I'd be riding more.
I hose the bike down if I have to, wait till it's dry and put more Squirt on, wait till it's dry and ride it again.
Posted : 30/05/2012 1:16 pm
I use finish line gold top wax lube on my SS, black gunky stuff builds up on the chain ring and sprocket, when it gets really bad, I scrape the worst off with a flat screw driver - lube the chain and ride. Can't do the same with wet lubes though, sticky as hell.
Posted : 30/05/2012 1:22 pm
with all due respect it sounds as though you've put too much on.
Squirt maintenance consists of [i]polishing[/i] the chain, brushing the cassette and chainring(s) with a clean toothbrush and then re-applying a drop of Squirt on every roller.
Posted : 30/05/2012 1:25 pm
rocketman - aye, you could be right. When I did first applicaton chain, cassette, jockey wheels and rings were squeaky clean and I applied like normal, back rotating the cranks to get a good dose on each roller. then every few rides, maybe 60-100 dry miles i give it a wipe with a clean rag and reapply. Does get a bit of a build up on jockey wheels and cassette eventually though. 5 mins with baby wipes last night took all the crap off though
Posted : 30/05/2012 1:32 pm
yup I would say that's the most it ever needs. I use the toothbrush on the jockey wheels as well the drivetrain looks sterile
Posted : 30/05/2012 1:47 pm
