Question for KS Lev...
[Closed] Question for KS Lev owners
Does the return speed vary with how much you press on the remote like the Reverb or is it just set by the air pressure? Can't find any mention of it in reviews or videos.
Posted : 26/02/2013 11:46 pm
Doesn't vary, doesn't matter to me, comes up at a steady speed, no drama, just works fine. Hope that helps?
Posted : 26/02/2013 11:54 pm
big help. thanks.
Posted : 27/02/2013 1:03 am
Actually, if you get the cable tension right, it can vary with lever movement but I've only ever done that in the workstand. Never used that "in flight".
Posted : 27/02/2013 5:38 am
Rate of return is set by the air pressure.
Posted : 27/02/2013 8:54 am
Yes, but return is also controlled by how wide the valve opens. It's just like adjusting rebound on an air fork.
If you've got a ks lev, try it. It works on my two.
Posted : 27/02/2013 8:56 am
Plus you can't adjust pressure on the 27.2.
Posted : 27/02/2013 8:58 am
@Onza Yes as you say in the workshop on the stand but when in use when the bike and you are moving about I cant see that you will be able or will notice the difference.
Posted : 27/02/2013 9:14 am
