So I have a tin, tried it and to be honest was unsure really the benefits outweighed the faff. It's bloody messy stuff. Albeit not as horrible as a well used wet lube setup. I may give it another go and wife the side of the chain down with a solvent. I ride in the FOD about 3 times a week and I found after a week of winter riding and cleaning it needed another lube. Which is a truck load of hassle. So I went back to wet Lubes.
Will give it another go tonight, but I'm less convinced
Hmm. I hate a claggy chain, so I use wax lube (epic ride or similar) in the summer and finish line wet in the winter. With the wet stuff, I wipe a drop across the sideplate junction, roller and sideplate junction on each link, on the inside of the chain (top of the bottom run of chain. Sounds faffy, but only takes a minute. But it is a bit faffy. And that's after a hose (every 2nd/3rd ride, probably) compressor to blast the water off and a wipe.
We'll see how the faff factor compares with the wax.
I don't have a problem with clagged up wet lube; I squirt bike cleaner on the chain then jetwash it whilst I do the rest of the bike. Gets all the grit out.
I've convinced myself that the faff it worth it because I don't wash bikes between rides. So an extra 20min lubing the chain once every couple of months is easily made up for by not washing the bike and chain before re-lubing every ride. I just get home, lock the bike in the shed and leave it till the next ride. No cleaning, lubing or tinkering.
What soils do you Putoline users ride on?
Swinley/Crowthorne, Tunnel hill/Farnbrough and the Chilterns. So a mix of sand and loam at the first two and plain old wet mud on the latter.
Can't really foo that for long where I live. Clay clogs everything up if you get onto some.
nedrapier - if you don't get on with it I'll buy it off you no problem.
Thanks TJ, I'll bear that in mind.
I noticed a few people gave Putoline a go after reading this thread. A few weeks later, how are you getting on?
After this weekends riding conditions, I'm thinking of giving it a go...
Also, how are people splitting 11 speed chains? Are there any reusable 11 speed quicklinks?
I use the £2.70ish ones from Merlin. YBN or something.
I did splash out on a proper bi-directional link tool to stop me firing them off across the kitchen too.
I have a used once tin of putoline if anyone fancies trying it. Its not for me!
Got my first Putoline'd chain drying in the shed, feels like a rite of passage 🙂
For the road bike. Was using Fenwicks stealth on the training bike which has been good but one wet ride and it needs re-doing. Hoping Putoline will stick around a bit longer. Just a tin and a hot plate here, it's not been much faff so far.
A couple of rides in with the putoline and it makes for a lovely smooth drivetrain. Now lets see how long it lasts when it gets grotty out there.
In the meantime I've done the XC, CX and turbo bikes 🙂 Quite a nice process, though need to remember that the oil is bloody hot when you get the chain out.
Anyone seen any data as to how it compares to stuff like Squirt in terms of efficiency?
I'm wondering about using it, local alkaline sandy muck drinks chain lube.
What do you use to degrease the chain before dipping it in the wax? Would shaking it up in a jam jar of petrol risk damaging the chain in some way?
It wouldn’t damage it.
But ffs, make sure the chain is bone dry after it, before you heat it up in hot wax, petrol can be surprisingly volatile eh.
Jam jar with white spirit / petrol is fine. Just make sure its evaporated off before you put it in the hot oil!
*beaten to it!*
Giant paper clip and some string makes pulling the chain out really easy!
Ha! Still got my tub, unopened since I bougt off the back off this thread first time round.
Still got plenty of wet lube left, but I might order another fryer (mine got sent back from the collection place when I didn't collect it quickly enough) and do all the bikes over Christmas break.
Or I might not. We'll see.
Nothing - just bang it in and swish it around.
Usually shake it in a pot of white spirits, then give it a quick wash, then pop it in the oven to dry. But with putoline i'm tempted just to pop it straight in the oil (if i had the chip fryer with basket I probably would.)
Used an old brake cable inner threaded through the chain.
I slosh mine around in paraffin, not so much for hte chain's sake as the rest of the wax, I don't want it mixed up with other stuff or full of dirt.
My tin is now almost at an end, Barely enough wax left in the tin to cover a chain and what there is is full of grit 🙂 Its lasted me years tho and I haven't used anything else on the chains for that time
Really must stop sitting in the fence and giving this a go. Normal lube just doesn't last here and shifting turns to crap quickly.
Fancy giving this a go. Any of the unconvinced want to offload their tin of Putoline before I go buy a new one?
Realistically,how many gritty wet nasty 20mile rides does one hot waxy dunk last?
scruff - MemberRealistically,how many gritty wet nasty 20mile rides does one hot waxy dunk last?
Depends on the exact conditions- I've sometimes redone it after a single race weekend, of really intrusive innerleithen clogged mechs death, or kinlochleven mud-powerwasher-riding-down-rivers. Generally I expect it to do maybe 4 or 5 orrible rides. I sometimes top it up with a liquid lube just to keep things sweet and prevent rust (which is the putoline's main failing, it lubes the bits that need lubed but it doesn't have a lot of rust protection for the plates etc)
And writing that down, it doesn't sound that great but with other lubes, I've sometimes ended up washing the bike in a river halfway through a single ride or carrying some lube to top up, or just suffered failing performance so 2 days of pain free motoring is a lot better.
That seems like a pretty serious flaw in the plan to me. If you end up adding lube anyway, surely it negates a lot of the benefits? OK, so you've still got a nice smooth-running internally-lubed chain, but you have to put lube on the outside to stop it rusting, which then attracts mud, etc. and turns to a dirty greasy mess?
That's a lot less than I expected. My current lube is Muc-off wet. I take a wee dropper bottle with me so I can apply some if I need to on a daily basis. But that typical day could be 50 miles or more of mud, rivers, peat bogs, beaches and dusty fire roads.
Having acquired a motorbike I was considering opting for Putoline for the push bikes but it doesn't seem worth the hassle.
thenorthwind - MemberThat seems like a pretty serious flaw in the plan to me. If you end up adding lube anyway, surely it negates a lot of the benefits? OK, so you've still got a nice smooth-running internally-lubed chain, but you have to put lube on the outside to stop it rusting, which then attracts mud, etc. and turns to a dirty greasy mess?
Nah, not really. TBH I really don't know what "attracts mud" means, when you're knee deep in mud you don't need to worry about whether you're attracting it or not, it comes to you anyway... The point of this stuff isn't that it somehow avoids getting muddy, it just cares much less
The corrosion thing is just for when the chain is still well lubed but the outer plates have had their coating worn off, which takes a few rides- it's not really an issue for offroad but it does matter if you're riding on salted roads. Same as other waxes really.
I guess what I mean is "retains" mud but
I take your point.
Will just have to try it I guess!
PS In case anyone missed it as it ended up last post on the page, if anyone wants rid of a tin of Putoline they're not getting on with, I'll buy it off you.
scotroutes, I currently use much off wet. It seems to barely last a 10 mile wet and muddy ride. How do you get 50 miles out of it.
It's also crap as soon as there is any dust - instant griding paste!
Not that a bit of corrosion on the outer plates is an issue, it’s just cosmetic.
Well, eventually it gets to be an issue but yeah, I'm really doing it for the cosmetic resaons
I'm still using my tin of Putoline despite saying I wasn't massively impressed with it. It's a guaranteed way of lubing the internals of the chain. Always rides nice and smooth after a dunking. I usually aim to get the worst of the muck off the chain before dunking it. Wipe the excess off chain with a rag while still hot. Top up with whatever lube every so often when the outside needs it (I won't use the words 'extremely sparingly' as I'm not that careful).
Dunno, but I'm not making it up or imagining it. Page Metalheart or Piemonster and they should be able to confirm it.scotroutes, I currently use much off wet. It seems to barely last a 10 mile wet and muddy ride. How do you get 50 miles out of it.
As for grinding paste - a sure sign of too much lube.
Took delivery of a lightly used tin of Putoline wax from papamountain today.
I might try and get hold of a deep fat fryer eventually, but in the meantime, how risky is heating it on a gas stove? I presume it's flammable, but pictures on the internet show the tin on a gas stove, so I presume it's OK if you're careful (of course, there's a lot of pictures of things on the internet that aren't OK even if you're careful).
...how risky is heating it on a gas stove? I presume it's flammable...
That's how we used to do it, on the gas ring.
Yes very flammable. Good idea to have a fire blanket handy.
Whatever you do, do not do it on your M-i-L's stove. 🙂
Practical experience is a great teacher...
It is pretty close to candlewax, it burns well. It also smells fairly horrible. But it really just needs a little care. I used to always do it on a camping stove in the garage
Glad you got it ok @thenorthwind. I stuck it on the kitchen stove when I used it. Weird watching it as it heats up, like terminator liquid metal man.
Once fully liquid I stuck the chain in and put the gas on low. Seemed to work fine. Ten mins and then hang it up with the tin underneath to catch the drips. Wipe off the outside while still hot.
Has anyone else had it go greasy?
Mine must be pretty old now (8 or 9 years?) but it doesn't seem as waxy as it used to be. Dunno if it's broken down with heat or just contaminated with other lube/water as I've never cleaned a chain before dunking it.
Still works, just lasts 5-10 rides between lubes rather than seemingly the whole winter.
Definitely one to do in the garage I think. Will keep me warm in there anyway! Might have a crack at it tomorrow.
Had a tin for about 3 months, but not been riding much. Rather than how many rides, its success might be better measured by how many times would you have to apply normal lube by comparison with one application of putoline? I reckon it's heading on for 10 times for me, but it's early days yet. To really make it a time saver I intend to share the faff by doing multiple bikes at once, and maybe doing 2 chains for my main bike and switching them once one needs a relube.
Well so far, I'm sold. Granted I haven't even ridden a single mile with a waxed chain yet, but so far it actually seems like less faff than lube.
It's more faff than sticking a bit of lube on your chain, but that's not really the point since sticking lube on a dirty chain isn't really helping much.
My previous routine was more like:
Ride with clean chain, come back muddy
Hose off drivetrain - should really clean dirty lube off chain but don't bother
Cover brake disc, spray with WD40 to stop it rusting while it dries
Lube when dry
Repeat until finally mustering enthusiasm to clean chain
Then, remove chain, soak in degreaser, spend half an hour thoroughly cleaning with toothbrush. Wipe dry, WD40, re-lube. Go back to previous routine for another 6 months
vs.
Wax on stove to melt for 10 mins, quicker than I thought (bonus: found a use for all those nearly empty cans of camping gas lying around that are no good for cooking)
Chain off, bit of wire through it, in the wax
Leave for 10 mins, do other jobs
Chain out, wipe down, hang up to dry (also doesn't seem to take very long), back on
To be honest, if the wax lasts even twice as long as lube, I'll be happy.
