Putoline question
Putoline question
Yeah but then it'll be out of sync, the extra narrow will mean that the next wide will be trying to fit into a narrow slot in the chain!
Posted : 04/02/2021 10:58 am
 J-R
@theotherjonv
suffice to say no-one makes 33 or 35T NW chainrings ‘for technical reasons’
- in that it is impossible.
Pedantically, if it ends with two narrows together, or two wides together, it is not a narrow-wide tooth pattern.
But more practically, on every second rotation of the chain ring all the wide teeth would be trying to engage into the narrow slots of the chain, which is not helpful for chain retention.
But getting back to the original subject of the thread, is there a consensus that Putoline should be used at around 120-140C and that 160+ is too hot? And a used chain does not need a degrease before it's first use of Putoline?
Posted : 04/02/2021 11:31 am
Yeah but then it’ll be out of sync, the extra narrow will mean that the next wide will be trying to fit into a narrow slot in the chain!
so make it a narrow?
yes I know, I think this is the third time I've argued this and still they come. FWIW the prime numbered cog thing is also BS. I can show you the maths for that as well
In other news, Mortimer and Whitehouse are doing an episode from STW Towers.
Posted : 04/02/2021 11:54 am
But getting back to the original subject of the thread, is there a consensus that Putoline should be used at around 120-140C and that 160+ is too hot? And a used chain does not need a degrease before it’s first use of Putoline?
I still think best practice would be to immerse chain at the hottest temperature you are comfortable with (I think I've used 180C but typically now 160C). This will help clean chain and makes wax as runny as possible to get right into rollers.
Then I just turn the fryer off and keep jiggling/checking chain until the wax is starting to solidify (takes at least half and hour) at which point I'll take basket out and hang on edge of fryer to let chain cool. I'll then wipe of excess whilst it's still a little bit runny, and job done!
One wipe with a GT85 rag and a first ride usually deal with any blobs of wax you've missed, especially if it's a muddy ride.
Posted : 04/02/2021 1:14 pm
I can't wait to see these jokers faces when you bring the math @theotherjonv
them apples
Posted : 04/02/2021 1:18 pm
Crikey some of you lot have a hell of a procedure.
When the chain starts making "dry noises" a quick shake in a jam jar of white spirit then into the pan of putoline ar 170 degrees. Turn off the flame let it site for 10 mins, fish it out with some pliers, quick wipe trying not to burn hand then straight back on the bike.
I don't do anything to it in between rides, just lash it away. Sometimes it will be really filthy the next time I get it out, a quick spray of wd40 and a run through a rag and its quiet again.
Sometimes if its been wet next time there will be a rust evident, just ignore.
Repeat every 3 months or so or when it sounds "dry". I rarely ever clean my bikes either.
Chains are cheap, I'll just replace when they start to show wear. New chains go straight in the putoline pan.
Posted : 04/02/2021 2:35 pm
Can hot wax really run out of the chain to any significant degree? I think that even if it's very hot, capillary action in the thin gaps between chain parts will mean it will retain a lot of wax.
I tend to run mine to the hot end of it's range, around 170, agitating the basket until it stops bubbling to make sure the air gets out and wax gets right into the chain.
Posted : 04/02/2021 5:32 pm
@alexnharvey - I don't know the physics, but at higher temps (say, above an indicate 150 on my cheapy DFF), I definitely don't get as long out of an application before the chain sounds noisy again.
Posted : 04/02/2021 5:48 pm
Well they say one good experiment is worth a ton of mouthflapping. Will try dropping the temp before removal next time.
Posted : 04/02/2021 5:51 pm
My current thinking is 160 for summer, 120 for winter.
Depends what you mean by significant. It still works fine at 160, but it is a lot thicker at 120 which means you have a thicker layer.
Posted : 04/02/2021 6:19 pm
 J-R
And the logic is?
Posted : 04/02/2021 8:50 pm
Clag
I'm sold on it, been on mostly my Hardtail this year with lockdown and the chain has just reached .75. that's unheard of for me.
Some truly manky rides after the admittedly glorious spring. Quite a few rides filling the drivetrain with Berkshire clag, followed by Swinley sand, then Berkshire clag again.
Plenty of Chilterns clag too.
Posted : 04/02/2021 9:16 pm
Damnit I added a photo to a post earlier.
Posted : 04/02/2021 9:34 pm
I think if you get it too hot excess runs out of the chain rather than holding in it.
Posted : 05/02/2021 7:59 am
And the logic is?
Hotter = thinner, so more runs out, meaning less excess and a somewhat cleaner drivetrain. Sufficient for dry summer conditions.
Cooler = thicker so more stays in, so lasts longer in filth.
It's only a theory. Warmer temps did work well for me this summer which was overall quite dry for me, I had a permanently clean drivetrain and I was getting loads of miles from one frying.
Posted : 05/02/2021 11:05 am
I emailed Putoline yesterday and asked what was the optimum temp.....
The melting temperature from this Putoline Chainwax product is approx. 55 degrees Celsius. Don’t heat it up above approx. 70 degrees.
Best Regards,
Bernard Voortman
Bernard Voortman
Technical Support Manager
Posted : 05/02/2021 2:36 pm
Lol, D'OH!
Interesting as I was about to post about the Silca Hot Melt Wax which only requires to be immersed in a pot of *almost* boiling water, but then the Silca stuff requires a clinically degreased and clean chain to start with...
Posted : 05/02/2021 2:40 pm
70? really? Blimey!
Posted : 05/02/2021 2:58 pm
I asked why and this was the reply..
It will evaporate (awful smell) and it’s starting to “burn” (higher temperatures).
The light wax/oil fractions will evaporates quicker than the more heavy ones and the rest product will be for that reason thicker
Posted : 05/02/2021 3:10 pm
Hmm.... could that explain the poor results some of us have had with our 'first' applications? We basically hadn't burned off enough of the light wax/oil fractions and these made the wax less durable?
Posted : 05/02/2021 3:22 pm
 J-R
Doh! Just dunked my first chain, in at about 150C, let it cool to 120C and out to hang.
I wonder if @tjagain has had his Putoline slowly change as it looses all the lighter parts of the wax mixture, but hasn’t noticed. Maybe time to buy another tin and compare in the name of scientific investigation TJ?
Posted : 05/02/2021 3:35 pm
Bugger.
Will try mine as low as it'll go next time.
Could try today, as it's a rest day and I plan to MTB at the weekend.
Posted : 05/02/2021 3:42 pm
Hmm…. could that explain the poor results some of us have had with our ‘first’ applications? We basically hadn’t burned off enough of the light wax/oil fractions and these made the wax less durable?
No you are not meant to burn off any of the compound.
I have my spare ready to go so I'm goin to do it again at 70 and see what happens (if my DFF will even go that low!!)
I still have half a tin left so I might swap it over in case i have ruined it by having it too hot.
I also asked if it was necessary to degrease a new chain....
It’s not necessary to degrease it before wax it. Only clean the chain from dust and dirty mud etc. Die the heat, the normal grease will be removed also for a part.
I think that means no - one can just dunk it in...
Posted : 05/02/2021 3:59 pm
Worth noting I don't get any bubbles and I get minimal smoke, so the lighter fractions can't be that volatile. Although if I dunk a chain that's dry but has had say Shimano Wet on it, I do see bubbles from the chain, suggesting that the wet lube has lighter fractions in it that are evaporating at fryer temps.
Posted : 05/02/2021 4:04 pm
I always clean my chain thoroughly (shaken in a pot of paraffin) before putolining. I have no idea if it's beneficial, it's certainly not 100% essential, but I just don't like the thought of putting a manky chain in clean lube. Doesn't take any length of time and definitely doesn't cause any harm so I'll keep doing it I reckon.
Posted : 05/02/2021 4:31 pm
Wow, so you’ve all been applying it incorrectly? Be interesting to see what happens with applications at 70degs
Posted : 05/02/2021 4:36 pm
For all those binning their fryers, Argos also do a mini slow cooker for £11.99 😉
I bought one cos I went with Molten Speed Wax, who say the correct temp is 93C (max 104C) so a fryer is too hot.
Posted : 05/02/2021 4:56 pm
Lowest setting on the dff is 80 degrees.
Just trying that now.
Though I went for an insanely wet ride earlier today, and my chain was still quiet at the end of the ride.
Was going to redo it anyway, so we'll see if lower temp = better.
Posted : 05/02/2021 5:20 pm
Hmmm, 15 mins at 80c and it's still solid.
Maybe we've been pranked?
Just read the safety sheet on the website, and the only temperature info is that the melting point is 68c and the flash point is approx 200c.
No warnings about heating to 120-150c.
Posted : 05/02/2021 5:26 pm
So I've just tried mine at 80 which is the lowest setting on the DFF. I used Mrs P's digital Thermapen meat thermometer (shhh!) and it said the temp was up near 100. I put the cold metal chain in and  the temp dropped to 70 but at that temp as soon as I lifted the chain out it started to set solid on the chain meaning there was 2 - 3mm of wax on it. Far too much for my liking. I put my finger in it and it wasn't too hot at all ( I have just done the same experiment on my hot tap which was reading 60 on the thermometer but was too hot to leave my finger in obviously.) I turned the DFF up to 120 and left the chain in until the reading on the thermometer was 100 and that seemed to be a much better temp - there was no smoke or horrid smell so I'm guessing I wasn't evaporating all the oils... I lifted the chain out gave it a wipe and hung it up. Seems fine......
I have emailed Bernard again to ask what's afoot with 70 as it seems too low.
Feel free to ask Bernard yourself though technicalsupport@kroon-oil.nl
Posted : 05/02/2021 5:49 pm
Ignoring potential wind ups and the probable lack of accuracy on a cheap fryer thermostat, I'd think a motorcycle chain would want a far thicker application than a tiny bycycle chain so would benefit from a lower temperature.
I have no idea on the temperature as I use a camp stove outside, I consider it a successful application if, when it cools, fast backpedaling makes the chain go slack where the links are full of wax.
Edit:- just saw the post using the kitchen temperature probe, brave, brave man.
Can I have your bike if she finds out?
Posted : 05/02/2021 5:54 pm
Can I I’ve your bike if she finds out?
She'll never find out. It's spotless again thank goodness 🤞 And I put new batteries in too for good measure. 🙂
Posted : 05/02/2021 6:03 pm
ON my second tin now and notice no difference in a new and old tin. I certainly heat it to above 100c
Posted : 05/02/2021 6:36 pm
 It’s spotless again thank goodness
And will last for ages with no awful grinding noises, win!
Posted : 05/02/2021 6:53 pm
Just to add another inane level of whataboutery to this discussion I did wonder if heating the chain up to >150 degrees would cause some problems for the pin/plates because of expansion? Another reason to do it as cool as it'll melt and run off?
Posted : 05/02/2021 6:57 pm
Ha ha that's hilarious. 🙂
In truth any of the cooking that requires the use of a thermometer is normally done by me - still she wouldn't be happy if she knew it had been in my bike oil!
My guess is that it must be more difficult to read the temp of wax oil for some reason -  I left the probe in until the temp stopped climbing so it wasn't a case that the wax immediately surrounding the probe cooled down and gave a false reading. It definitely wasn't at 70 degrees though as my finger will confirm.
I have to say I'm puzzled.
Posted : 05/02/2021 7:05 pm
Just did two chains in cooler wax. Took ages to heat up, and the wax was definitely thicker. Set the dial to 120 and it obviously wasn't that hot, did one chain that way as normal. Some bubbles came up on agitation. Let it cool to around 90 on the dial, dunked the chain and it came up a congealed black blob so clearly too cool.
Posted : 06/02/2021 3:22 pm
NO! Having spent the last few years free styling Putoline on a camping stove in the garage a couple of days ago I pushed the £15 click and collect button for the DFF from the ‘gos (as frankly there is F all else exciting these days), was going to pick up this afternoon BUT now...
Posted : 06/02/2021 3:33 pm
@molgrips I would guess that dunkin a cold chain in the lower temperature wax would seriously lower the wax temp even further and it would probably take a relatively long time for both the chain and wax to get back up to temp. You didn't say how long you left it in for? Must admit, I'm a bit doubtful of the lower temp advice given further up the thread but am willing to be educated.
Posted : 06/02/2021 6:59 pm
Suggest leaving the chain on top of the wax while it heats so it’s less cold when it goes into the wax.
I wonder if the DFFs have an actual thermostat or if the temp readings are approximations for oil temps? Might explain why they’re so far out.
Posted : 06/02/2021 7:07 pm
Just took the plunge and ordered a tin of putoline. I'm currently using molten speed wax on my mtb and road bike. I have 4 chains in rotation on my road bike and it's been a bit of a faff this winter, since MSW doesn't seem to last more than a couple of rides on a chain and often I'm left with a rusty cassette and chain links after wet/damp rides.
I'll just put the chains in boiling water to clean them and then replace the MSW in my slow cooker with the putoline.
Do many others use putoline on their road bikes? Get any rust, or just wipe down with a GT85 rag?
Posted : 06/02/2021 7:23 pm
I have no idea what temp my fryer does it at- I just treat the chain when the consistency feels right, which for me is thicker than oil, thinner than custard. Precision!
Posted : 06/02/2021 7:28 pm
Did a couple of experiments with my Asda DFF (£15) and my contactless temperature gun.
Surprisingly, the temperature settings on the dff are surprisingly accurate... almost perfect.
Heated up to 120 degrees then left to cool, the Putoline was still very much a thin liquid at 70 degrees, and started to thicken up as it dropped through the 60s. Solid by about 64 degrees.
Posted : 06/02/2021 9:53 pm
Yep, on the winter road bike. I just wipe down with GT85 after each ride, very little rust, much cleaner than previous wet lube applications, quiet and durable. Pretty pleased.
Posted : 06/02/2021 9:59 pm
I feel this is how we should measure viscosity from now on
Page 12 / 17
