Push-on mini pump a...
[Closed] Push-on mini pump as good as a Lezyne Alloy Drive?
[#4105833]
I have an excellent shiny lovely Lezyne Alloy Drive in my Camelbak but since I switched to removable core valves (much easier for tubeless) it is now next to useless as when I unscrew the pump's connector from the valve it tends to take the valve core out at the same time - instant deflation! What's as good as the tiny but powerful Lezyne but pushes onto the valve?
Posted : 26/06/2012 8:10 pm
Is that a "no, there isn't"?
Posted : 02/07/2012 3:26 pm
Screwing your valves in properly.
I use a lezyne, never ever have that problem.
Posted : 02/07/2012 3:30 pm
 mttm
Try tightening the valve cores a little bit more? The Stan's tool for this is about a [s]fiver[/s] £7.60, lot's cheaper than a new pump.
EDIT: here
http://www.wiggle.co.uk/stans-no-tubes-core-remover-1/
Posted : 02/07/2012 3:33 pm
You got a valve core tool you can tighten them with?
Dab of locktite so you can never get them out agen?
Or maybe Edinburgh Bike Co-op pump?
Posted : 02/07/2012 3:37 pm
Maybe the valves are knackered but this isn't a first time problem and it happens however tightly they're screwed in.
Posted : 02/07/2012 3:45 pm
i know what you mean as i have experienced the same with my Lyzene...
not really a massive issue or worth buying a new pump. jog out now into the garage and nip up the valves with a pair of pliers. if you're really worried drop a dab of loktite onto the core...
serisly...?
Try tightening the valve cores a little bit more? The Stan's tool for this is about a fiver £7.60, lot's cheaper than a new pump.
EDIT: here
a specific tool for a job that can be done with your teeth if need be....?
Posted : 02/07/2012 4:05 pm
 mttm
Yes, a specific tool - strangely this tends to make the job a bit easier. You can use pliers, but they will chew up the very thread which the OP requires to attach his Lezyne pump to.
Posted : 02/07/2012 4:19 pm
Yeah, pliers do the job, but the tool does it properly, and is very nice to use.
I've done it with a tool and with pliers - the problem still occurs!
Posted : 02/07/2012 4:25 pm
Lezyne Speed chuck any good?
Posted : 02/07/2012 4:31 pm
I had the same issue after my mate was the designated pump carrier & bought a Lyzene pump.
I settled on a topeak mountain morph mini. super fast, super easy, not so light (but I ain't a racer and I'm more overweight than the weight of the pump). Had it for a year in my Camelbak & (touch wood) the most reliable pump yet (C02 pumps excluded - which I also stopped using when they curdled the Stans Fluid in my tubeless set up).
HTH
Posted : 02/07/2012 4:36 pm
 igm
Same problem - same topeak solution.
Posted : 02/07/2012 4:52 pm
