... the mighty Mountain Morph? Mine must be 15 years old, but sadly I've left it on a trail somewhere 🙁
I don't need a gauge, I don't need it to fire up a Co2 Cart. It doesn't need to be small as I have a smaller one for local rides. This is my work every time, shift a decent volume of air all while acting like a mini track pump with the fold out foot.
Oh and while I'm up for looking at other makes, please nothing with those super annoying valve remover screw in/on/off things.
Not that I’ve used.
Love my Blackburn mammoths, nice volume and a tee handle.
Years in wet bags and bolted onto bottle cages through winter and have never missed a beat.
I have a bontrager mini floor pump
Awesome bit of kit and years old
Wish it would fit in my arse pack
Co2’s and small pump still not a match for the Bonty
That Bonty pump does have a longer hose which I like the look of. And that mammouth has the same 'Cockroach' look as my Morph. I'm torn now!
Have a 20 year old Mammoth that has seen off numerous pretenders. Rebuild kit returns it to new performance once rubber parts start to stretch. Reckon it will outlast my knees.
Lezyne HV Micro Floor Drive works ok (I use it with the screw-on fitting as I've not removed a core with it yet). For £3 you could use one of these instead
Had mountain morph, now got the lezyne high volume equivalent. Lezyne ok but I preferred the mountain morph. It just worked, lasted for years and it was probably quicker/higher volume. On the lezyne the screw chuck is more faffy and the gauge is only for road pressures despite being the HV version, but otherwise it is working fine and does feel more solidly built. If you go lezyne go without the gauge.
I’ve got an ancient lezyne mini floor pump that’s still going strong. It’s shiny silver and never failed.
No idea if it’s any better, stronger, or cheaper than what you had though.
I think I'll stick with the Morph. Thanks all. It fits in the big pack and I know I can rely on it in any conditions. I might get a DA for my smaller pack tho. Not seen that before.
I love the Lezyne stuff normally. Bit that screw on chuck thing. I do not want that in my life 🙂
