PSAs that may or ma...
[Sticky] PSAs that may or may not be amazing enough to warrant their own thread 2026
Garmin Fenix 7 Pro Solar for £340 on Garmin's Amazon Store
Posted : 12/05/2026 7:45 pm
Posted by: nickingsley
Just a note with that one - being just the Solar (not solar sapphire), it won't have sapphire glass. Also, solar doesn't charge, it stops the battery draining quite as quickly in the right conditions.
Fenix have slightly longer battery life due to the duller (but arguably better in bright daylight) MIP display. Epix have a brighter amoled display. I'll still get 20 days out of the Epix.
Posted : 14/05/2026 7:06 am
20 days navigating! My (now sons) Epix Gen 2 never did that.
I cant comment on the difference re Sapphire, but I used my Fenix 7 Pro Sapphire Solar to navigate for 6hrs yesterday (rain/cloud occasional sun) and the battery dropped from 74% to 55%. Yep, a bit a**l, but I was specifically checking performance.
Posted : 14/05/2026 8:34 am
£330 today.
Re @TheArtistFormerlyKnownAsSTR comment, I only wear my Garmins when following a route or recording an activity. Used the Epix to tell me my sleep for a few days was poor and then stopped using it as a watch.
Posted : 14/05/2026 8:57 am
20 days navigating!
Who mentioned 20 days navigating? 🤣 No watch is going to do that
Posted : 14/05/2026 11:26 am
I use my Fenix 6 solar for Strava tracking at least 2 hours a day and wear it 24/7. I charge it every 3 weeks-ish, and even then it usually has about 20% charge left. The solar definitely keeps things topped up; I always make sure the watch isn't covered by my jacket/glove.
Absolutely fantastic bit of kit, would highly recommend a solar Fenix to anyone!
Posted : 14/05/2026 1:28 pm
nickingsley reacted
Posted by: a11y
Rear shocks in various but fairly common sizes, e.g. 190x45 RS Deluxe Select for £80ish delivered - may or may not face additional duties (but eBay checkout stated not). Seller is a known retailer in Germany I've used before.
https://www.ebay.co.uk/sch/i.html?_dkr=1&iconV2Request=true&_blrs=recall_filtering&_ssn=radsport24&store_name=radsporthandelrog&_oac=1&_nkw=rear+shock&store_cat=15248904011
Bought one as spare for my Tallboy. Nothing fancy but might stick it on for winter use to save my fancy shock.
Got a couple of these as possible 100->120 travel increase for my Sniper and Mrs B's Blur, also as bargain backup.
No extra charges over and above the number paid on Ebay. Delivery took 3 days or so I think.
Got a Fox 165x45 Trunnion for the Sniper which decoded as: 2022 PERFORMANCE SERIES FLOAT 3POS, Part number: 972-05-068 Description: 2023_22, FLOAT DPS, P-S, A, 3pos, Trunnion, Evol LV, Lapierre, Zesty TR, 165, 45, 0.6 Spacer, LCM, LRM, CMF, Standard Logo. Which is nice, because it's the exact same tune as the Sniper.
The 195x45 Deluxe Select is pretty basic, just rebound adjustment. Decodes as this on RS site:
Model ID: RS-DLX-SEL-C1
Air volume DebonAir Linear
Damper Type R
Rebound tune Linear
Compression tune L
Volume reducer 0 Neg 2 Pos
Check Tune 0 - Light
Everything else n/a or obvious.
Yet to establish if this matches Blur tune, but seems innocent enough so likely OK.
£165 delivered for the pair.
Posted : 14/05/2026 10:56 pm
Some cheap cannondale bits on sportpursuit
£19 mips helmets
£13 saddles
etc.
https://www.sportpursuit.com/sales/cannondale-may26?sp_nav=ct-11.ev-33130.&p=2
Posted : 15/05/2026 6:26 am
roger_mellie reacted
^ those helmets and saddles look good.
Posted : 15/05/2026 8:51 am
@wukfit . Thanks for that. Got a helmet, bottles and a saddle . All of which I needed to replace soon anyway
Posted : 15/05/2026 9:16 am
Thanks - ordered a helmet as been looking for one with a helmet mount. The USE exposure mount is really poor fit on my current one.
Posted : 15/05/2026 3:44 pm
OneUp Components - only sale until November,
https://uk.oneupcomponents.com/?mc_cid=bbc204b1cf&mc_eid=b20f58f768
Posted : 15/05/2026 8:52 pm
Cheap £23 but very purple trousers at Evans.
I've been wearing the black versions of these since CRC had their closing down sale. I've bought some, they are just as purple in real life!
https://www.evanscycles.com/brand/nukeproof/mens-trail-mtb-trousers-333839#colcode=33383924
Posted : 16/05/2026 3:56 pm
They must be very special if they did cost £240 before the discount!
Posted : 16/05/2026 5:07 pm
 nuke
Bargain but Im not brave enough to go full trail Joker
Posted : 16/05/2026 5:53 pm
They've got the slightly less bright purple ones for forty quid too.
I've got a pair of the black ones, they're ace.
Posted : 16/05/2026 8:46 pm
How do they size up? I'm not interest in how ridiculous I look so will happily wear those... 34 inch inside leg and a 37 inch waist...I'm guessing XL at least...
Posted : 16/05/2026 9:56 pm
They used to be true to size, but reports of them being all over the place since the demise of CRC
Posted : 16/05/2026 10:12 pm
Wow! If only they were flares! 🕺
Posted : 17/05/2026 7:16 am
Got some ordered and I'll soon see if my measurements are right!
Thanks for the link.
Posted : 17/05/2026 8:36 am
tall_martin reacted
I've got a 36 inside leg and a 36 inch waist according to most trousers. My waist is definetly bigger than that.
The large fits me well.
Posted : 18/05/2026 6:28 am
48 hour delivery turned on a 16 hour delivery. They've arrived and they fit nicely, so my XL order was right...but suspect my waist isn't as small as I thought!
Properly thin material so shouldn't get too hot. Arrived stickered up with a price tag of £240...genuinely can't see that being right! Also has a 50% off tag with £119 written on it...still can't see them being that much brand new, however for £24 + £7 delivery, I'd say they were well worth it.
Posted : 18/05/2026 4:21 pm
tall_martin reacted
Looking at those shocks, are there any rules of thumb when converting from RS to fox, and air to coil?  Or are coil shocks generally all much more similar because they all share the same linear spring rates anway.
Posted : 19/05/2026 4:24 pm
I have looked at those shocks a few times but the risk of getting the compression or rebound tune wrong is putting me off
Posted : 19/05/2026 4:47 pm
Posted by: thisisnotaspoon
I've found google Gemini is pretty good at summarising the suitability of the shock based on your bike and what it currently has fitted.
Posted : 20/05/2026 9:46 am
DJI power 1000 V2 are £469 at the moment. Decent price for those with e bike batteries to charge at tail centres at lunch time 🤔
Posted : 20/05/2026 7:27 pm
I posted this in the Sleeping Pad thread, so I'll stick in here.
ALPKIT WHISPER SLEEPING PAD
Was originally £84.99, now down to £69.99. Use code GETOUT20 to get a further 20% off, down to £56
ETA: Almost everything is subject to the 20% code
Posted : 21/05/2026 7:59 am
Curious about those battery packs mentioned above. How would that work realistically I’m wondering. My bike has a built in 400wh battery and 250wh RE. Even on mains however, it takes 3 or so hours to charge. My logic would be then, what size battery booster thing would you need for a lunch hour charge?  Is it simple as saying 1 hour of charging would get around 150wh, less 20% loss, so ,albeit a 200wh battery bank would do as a top up? Having written all that, such a product seems like it would be pointless for the benefit so forget all I wrote.  Better, I imagine, to have too much capacity in the booster pack.
Edit, something like this might get a single charge on an overnight somewhere without a mains supply?
https://www.decathlon.co.uk/sports/camping/batteries-cable-reels-and-power-banks?pdt-highlight=e201fa08-3e49-4460-85ee-f5fbe12498a2&vc=c3&utm_source=google&utm_medium=cpc&utm_campaign=gb_ct-shopp_t-perf_nc-mp-stars-perf_ts-pro_f-cv_o-reve_spd-msp_spu-msp_sp-msp_pt-mkp_pnl-ecom_l-en_bm-roa_sg-na_xx-mp-stars-perf_&utm_term=ts-pro_spd-msp_spu-msp_sp-msp_pt-mkp_l-en_yy-mp-stars-perf_&utm_content=zz-mp-stars-perf_&utm_id=23835682005-195673266239-&gad_source=1&gad_campaignid=23835682005&gbraid=0AAAAADygKq2xo6HRrpp-tLaCSx4JG2ja0&gclid=EAIaIQobChMIgtTwzYrKlAMVrZNQBh3y4TdLEAQYBCABEgIE6_D_BwE
Posted : 21/05/2026 10:33 am
retrorick reacted
Posted by: retrorick
I'm a bit puzzled - they still sell the V1 but the V2 seems cheaper and better?  And there's a mini as well
For charging a single bike wouldn't the mini be the best option?  It'll do 800w so more than enough for the fastest bike chargers (which are about 500), it's 3kg lighter, smaller and, if you want to charge it from your car while you're driving, works out £125 cheaper because the adapter is built in.
Posted : 21/05/2026 11:49 am
retrorick reacted
Burgtec shimano chaintrings cheap. Ordered blue 30t on Monday and arrived on Wednesday.
Only 1x blue 32t, 1x cash bronze 32t and 2x red (30t and 32t) left.
https://www.trekstore.co.uk/shop/components/chainrings/burgtec-thick-thin-chainring-for-shimano-direct-mount-8519/option/
Posted : 22/05/2026 6:31 am
M&S Selvedge jeans. I’ve got 3 pairs now they’re so good.
https://www.marksandspencer.com/slim-fit-japanese-selvedge-stretch-jeans/p/clp60562354#intid=crosssell_altfit_T171520S_P60452790
Posted : 22/05/2026 9:00 pm
Watty reacted
Ortlieb bar bag.
(Ignore the ebike moniker, the light shadoofer and you have a good Ortlieb bar bag with bottle mounts at 70% off. Two colours available)
https://www.balfesbikes.co.uk/accessories/packs-luggage/ortlieb-e-glow-handlebar-bag-for-e-bikes-in-petrol__49615?
Posted : 22/05/2026 9:28 pm
Electric inflators following on from the thread. The cheapest of the ones ZeroFrictionCycling rated highly is the Muc-Off.  £100rrp, can pick up for about £75 discounted.  But appears to be a rebranded RockBros inflator which you can currently buy from the  on Aliexpress for £51 (lowest price for 90 days supposedly).  As ever theres a risk on Aliexpress that you don't actually get an original item...
https://www.aliexpress.com/item/1005007010175543.html
Posted : 24/05/2026 12:34 pm
Most of them are made by the same company and just rebranded. This is the OEM
https://cycplus.en.alibaba.com/productgrouplist-924413207-2/Smart_Bicycle_Pump.html
I've been using this since last year and it works fine. If running TPU tubes I'd definitely want one with a hose as they get fairly warm.
https://www.aliexpress.com/item/1005008660203645.html
Posted : 24/05/2026 4:24 pm
AliExpress = just say no.  Who knows what quality, copied IP, duck import taxes, who knows what children they employ working 14 hour days, no sustainability... There's no checks, no QC.
Just say no.
Posted : 24/05/2026 5:00 pm
felltop, geck0, tomtomthepipersson and 1 people reacted
Might come out of the same factory and share a case but Adam at zfc has already proven that good design elements from customers are not automatically applied to in-house products.
Posted : 24/05/2026 5:07 pm
Posted by: b33k34
Anything with MucOff written on it is garbage IME. I’m surprised at ZFC recommending that. Their opinions have gone down in my estimation based on that.
Posted : 24/05/2026 7:23 pm
Posted by: b33k34
Posted : 24/05/2026 7:24 pm
Posted by: b33k34
Don't worry, you should have heard him rip into their new drip wax on Friday.
In all fairness to Adam, you have to respect that he can put their chain lube aside and review their mini pump on its merits
Posted : 24/05/2026 8:34 pm
b33k34 reacted
Ortlieb bar bag.
Does it need the specific e-bike mount (that costs almost as much again) or does the normal one at half the price work?
Posted : 26/05/2026 2:59 pm
Ortlieb bar bag.
Apparently any Ortlieb or Rixen & Kaul / Klicfix
We've the Rixen & Kaul.
Posted : 26/05/2026 4:23 pm
E-Thirteen Vario Infinite Dropper post half price using offer code VARIO50CRASH
https://ethirteen.uk/products/vario-dropper-post
I contacted them for a service kit for my old E-Thirteen post and gave me the code instead, as they didn't support the old post anymore.  Very kind of them thank you very much.
It is just for the post mind you, lever separate and not discounted.
Posted : 27/05/2026 4:32 am
Posted by: matt_outandabout
Ortlieb bar bag.
Can confirm they go straight onto Rixen & Kaul, more firmly held than a 'proper' R&K Klicfix bag before it.
Posted : 27/05/2026 6:17 pm
Page 11 / 16
