PSA: shockwiz £179....
[Closed] PSA: shockwiz £179.99 @ CRC
[#10985757]
Been shocked curious for some time cheapest price I’ve seen , £35-50 hire a week on eBay ..
Anything thing to be aware of new model out, missing parts etc
British cycling takes another £10 off
Posted : 01/01/2020 3:40 pm
Bargain!!!!
Posted : 01/01/2020 4:17 pm
Make sure your shock is supported (Fox EVOL isn't for example)
Posted : 01/01/2020 4:40 pm
Is the EVOL not compatible? I thought it would work with any self single valve air spring with a self charging negative chamber.
Posted : 01/01/2020 4:53 pm
Am i right in thinking this will work with the Cane Creek Air Inline shock? Do you just need an additional hose to connect it to the air valve?
Posted : 01/01/2020 5:02 pm
I think, depending on year, there might be an issue with the angle of the valve on the shock.
Have a look at the shockwiz site, there's a comparability list.
I've just ordered a second one off the back of this PSA so I can do both ends of the bike at once.
Posted : 01/01/2020 5:15 pm
Does anyone know please, are these compatible with Fox 36 Grip 2?
Posted : 01/01/2020 5:25 pm
No reason why it won't work with the Fix 36 grip2.
The only stuff it doesn't work with it when positive and negative chambers either fill separately or have a volume that can change during use.
The 36 is a single air chamber with a self charging negative chamber via a "dimple" transfer port.
There is a naked tr evil used on some Scott bikes that it doesn't work with.
Posted : 01/01/2020 5:31 pm
Thanks - I didn’t know how the negative chamber worked, hence the question over compatibility.
Although will it be able to recommend setup based on both high speed and low speed rebound?
Posted : 01/01/2020 5:52 pm
Should do yes.
Posted : 01/01/2020 5:59 pm
Shock swizz !!
Posted : 01/01/2020 6:27 pm
Shock swizz !!
I'll bite, go on then, elaborate?
Posted : 01/01/2020 6:32 pm
I’ll bite, go on then, elaborate?
Would be interested too. I quite fancy the idea of some geekery to either help me get the bike setup or confirm it's pretty good already....if it works. I constantly wonder if my setup is screwing a suspension design someone spent months perfecting.
Positive and negative experience of one of these welcome.
Posted : 01/01/2020 6:37 pm
I've done 5 bikes with mine, 2 of mine and 3 mates, all were impressed.
Even a resident pro from the forum tried mine on his and even though he didn't need to change anything much, the Shockwiz agreed with his settings.
Posted : 01/01/2020 6:42 pm
Bought , the British cycling £10 crc codes are now up so an even better price
Posted : 01/01/2020 6:50 pm
Damn you OP
Bought
Posted : 01/01/2020 10:16 pm
 mos
Kerching, Ta.
Posted : 02/01/2020 10:10 am
Bah! I'm too skint already!
Posted : 02/01/2020 10:12 am
