PSA: Discounted Pin...
[Closed] PSA: Discounted Pinnacle frames at Evans
For those who have ordered a Iroko how is the rear tyre clearance when running a 29er rear?
Ordered one for use as a modern 29er HT replacement for my stolen hardtail so fingers crossed its a goer. Looking to run a 2.35 max 29 in the rear.
Any luck with Evans supplying the frame cable mounts?
TIA
Posted : 02/02/2022 11:27 am
I'm sure I read the 2.4 was the max tyre width for 29. can't find where I saw that though.
Easier to just order some cable mounts (Wiggle, Ebay etc). Can't be arsed with the hassle of trying to get them from Evans
Posted : 02/02/2022 12:15 pm
No word yet from Evans re the guides. I can get guides easily enough, it's the gromits on the internal routing I'm more worried about.
Posted : 02/02/2022 1:28 pm
I ordered some Nukeproof ones - noticed afterwards there are tons of options on ebay. So if they don't fit, I'll go there (or just get some Sugru and make my own.)
Posted : 02/02/2022 2:36 pm
Here's a 29er x 2.4 tyre in me frame. Not the widest rims (old Stans Flow), but enough clearance.
Posted : 02/02/2022 11:17 pm
These are a perfect fit for the top tube. Had to get the triple guides (might get away with the singles, wasn't sure), but they're hidden underneath, so it won't notice 🙂
https://www.chainreactioncycles.com/ragley-universal-cable-guide-kit/rp-prod104665
Posted : 04/02/2022 12:01 pm
I had the same experience of having to take a photo of missing items. Any joy in the end for getting the correct grommets / guides?
Evans customer service was useless. They told me to order some off Amazon. They couldn't even tell me which ones nor cared about finding out.
Nice frame though...
Posted : 15/02/2022 11:33 am
I'm interested in getting one of these for my daughter, she's 12 and 170cm and I suspect she's still got a bit of growing left. She was riding my friends M Whyte 901 yesterday and it looked the right size for her. The M 2019 901 has the same reach as the L 2017 Iroko. (according to geometrygeeks.bike) the 2020 Iroko is meant to be slightly longer so the L might be good for a bit more growth.
Also, I'd be looking to build it up with 120mm 29 fork (Fox 32), then either run a mullet set up (2.6) or 29 rear (2.4). Was a bit worried about raised BB height going full 29.
Anyone got any thoughts/suggestions about either?
Ta
Posted : 20/02/2022 9:07 pm
The reach (literal, rather than geometry) will be far too much on a large frame for someone 170cm. Would be very unwieldy til such time as she grew into it.
Posted : 20/02/2022 9:40 pm
I've finished building my Ramin, had a little ride on it yesterday, conditions were too snowy to get a proper feel for it!
Ramin
Snow
Posted : 20/02/2022 10:24 pm
Thanks, will order the M and have a play with different rear wheels. That Ramin looks ace!
Posted : 21/02/2022 12:29 pm
Hoping I didn't give @hopefiendboy a bum steer (^^ up there) regarding the 29er tyre size in the rear. Had the bike upside down and didn't notice how close my tyre was to the seat tube. ie. very
Posted : 21/02/2022 3:25 pm
Ahahaaaa. Yes, I ordered the frame and the seat tube clearance was terrible so I sent it back. Evans was unhelpful with the frame specific fittings too. Cost be 20 quid in.postage 😞
Posted : 21/02/2022 3:29 pm
Oops, I can only apologise 🙁
Posted : 21/02/2022 3:53 pm
Hmmm, tempted to cancel my order if a 29 rear isn't really going to work...
Posted : 21/02/2022 5:30 pm
If you ru a 1.9 on the rear it.might be ok but anything larger forget it
Posted : 21/02/2022 11:29 pm
Correct ^ It's a 650B frame, you won't get a 29 tyre in there. Gravel / 700C commuter tyre maybe.
Posted : 22/02/2022 8:47 am
Had the bike upside down and didn’t notice how close my tyre was to the seat tube. ie. very
@desperatebicycle
how close is close?
I recall my first fisher 29er was pretty tight to the seat tube, maybe 4-5mm clearance with a 2.25, but it was designed for 2.1
Posted : 22/02/2022 10:13 am
My tyre was the one in the background of my photo, a Goodyear Peak 2.3, which is pretty-much a semi-slick and was probably 3mm from the seat tube. So you [i]would[/i] get one in there, but choice is limited.
Posted : 22/02/2022 4:14 pm
Description on Evans' is slightly misleading "Typically designed for 27.5" wheels, this frame also has clearance for 29" wheels"... Wheels. Just not tyres, obv. 🙂
Posted : 22/02/2022 4:31 pm
^ Don't know where that came from. It has a 425mm rear end and a straight seat tube that's not that steep by today's std. ~740mm OD tyre would contact the seat tube and a 29" wheel is about that or more. 27.5 x 2.6 will fit from what I remember being tried out on the frame.
Posted : 23/02/2022 8:19 am
Thanks for all the advice above.
I've gone with a mullet build in the end, 27.5 (2.6) on the back and 29 (2.35) on the front with a 120mm 29 fork, seems to be pretty well balanced and doesn't look obvious. Build has come in at 13kg, Size M fits my 170cm 12yr old perfectly with hopefully a bit of space to grow, she's well happy with it.
My pal who's a very good rider and the right size (I'm a bit big at 6'3") had a razz on it yesterday and was vey impressed and didn't think the geometry was compromised as a mullet for climbing.
Iroko Mullet
edit: bah, cant get image to work but hears the direct link:
https://www.flickr.com/photos/191420910@N06/shares/A47M80
Posted : 14/03/2022 11:03 am
[url= https://live.staticflickr.com/65535/51937451326_d1f764dbd1_h.jp g" target="_blank">https://live.staticflickr.com/65535/51937451326_d1f764dbd1_h.jp g"/> [/img][/url][url= https://flic.kr/p/2n8x1NJ ]IrokoMullet[/url] by [url= https://www.flickr.com/photos/191420910@N06/ ]Tom Crow[/url], on Flickr
Posted : 14/03/2022 11:36 am
Similar to mine. Odd wheels, old Fox 32s (mine are white). I bought some of those £30 cranks from Ebay. I've ridden it twice then injured myself, but it felt pretty good.
Posted : 14/03/2022 12:05 pm
Looks great that..
A 120mm 29er is a good swap for a 140mm 650B front end. Forks pretty much the same length. You get a good amount more trail / stability from the larger f wheel but the angles don't slacken + BB doesn't raise as much as if you got that same trail increase by keeping the 650 f wheel and adding a longer fork only. Maybe I missed them on here but I'm suprised there don't seem to be more mulleted 650B HTs around.
Posted : 14/03/2022 1:27 pm
Here you go, another Iroko Mulatto
Note the fake Xt cranks. Beauties.
Posted : 15/03/2022 2:27 pm
those iXT cranks are actually OK. do the job, not the lightest, but seem to be fairly sturdy.
Posted : 15/03/2022 5:54 pm
yeah, they seem fine - 480g I think they are (without chainring)
Posted : 15/03/2022 6:57 pm
Really capable frame. For the price of the frame and the performance it is hard to beat. Build a really nice spec'd unit with advent x, RS 35s, NP wheels for small money.
Posted : 15/03/2022 8:09 pm
Did anyone find grommits for the dropper routing, or is everyone leaving them open? My son's build doesn't have a dropper yet, my backup plan is a sugru plug.
Posted : 20/03/2022 7:52 pm
Yeah, as mentioned further up, I bought some Nukeproof ones. Can’t find the Crc link, if I do I’ll post it. They aren’t exactly the right shape, but you press em in and they stay put.
Posted : 20/03/2022 9:04 pm
Ah, cos it was Wiggle not CRC and Ragley not Nukeproof!
these is them though
https://www.wiggle.co.uk/ragley-internal-cable-guide-3pk?sku=101780805
Posted : 20/03/2022 9:22 pm
Page 2 / 2
