PSA - 200mm brand X...
PSA - 200mm brand X dropper £90
 cp
[#13028868]
Cheap dropper for all those cheap ragley frames.
31.6 only
https://www.chainreactioncycles.com/p/brand-x-ascend-xl-dropper-seatpost-170-and-200mm?color=black&travel40011=200mm+Travel+%7C+559mm+&seatpostDiameter=31.6mm
Posted : 04/11/2023 10:10 am
 cp
Also, headset to suit the alu frames 6.99 (worth a couple just to get spare bearings).
https://www.chainreactioncycles.com/p/nukeproof-neutron-zs44-zs56-headset
And cheap ht2 bb's
https://www.chainreactioncycles.com/p/nukeproof-neutron-bottom-bracket-shimano-24mm
And finally... Cheap steerer cutting guide
https://www.chainreactioncycles.com/p/lifeline-saw-guide
Posted : 04/11/2023 10:14 am
Ace! Thank you. Hoping the 200 fits my medium now!
Can these be shimmed?
Posted : 04/11/2023 10:45 am
Cheers, just saved me a few quid on a dropper
Posted : 04/11/2023 10:58 am
Had one of these in my basket from yesterday but it had sold out earlier this morning.
Went for a fox transfer for £117 instead.
Posted : 04/11/2023 1:29 pm
I missed out on the 200 Fox at £117 damn.
Posted : 04/11/2023 1:54 pm
 cp
Downside to the fox is you need to buy the lever as well
Posted : 04/11/2023 1:59 pm
True but I already have my go to lever from Shimano, the MT500 at £20 which is as good as any and far better than the Brand X.
Posted : 04/11/2023 2:04 pm
ordered the transfer on Saturday arrived today on free postage option
Very OEM just in a plastic bag - but it came with a trigger as (with out a bar clamp though) - so real bargin..
any one know if those cheap  headsets bearing would fit in a hope headset ?
Posted : 05/11/2023 4:47 pm
but it came with a trigger as (with out a bar clamp though) – so real bargin..
Fingers crossed mine has the same!  Is the one that came with yours MMX or ispec fitting?
Posted : 05/11/2023 6:56 pm
its just the lever with two bolt holes for sram i think,
google for Aluminum Alloy Bike Clamp, Bike Shifter Clamp Bicycle Trigger Clamp 22.2mm, Sram Shifter Clamp with Bolt
that will be cheap option to directly attach to bars
I'm a dinosaur running 2 * 11 still - so hopefully the old crank brother lever which just about fits with my rapid fireshifters will work with it
Posted : 05/11/2023 11:40 pm
I've only ever heard bad things about the Transfer unfortunately
Posted : 06/11/2023 7:33 am
I’ve only ever heard bad things about the Transfer unfortunately
One of my riding pals has had one for 5 faultless years.  I'm confident that there would be warranty back up if needed.
Posted : 06/11/2023 10:44 am
Transfer is too long to fit in my frame. Bugger.
Back it goes 😂
Posted : 06/11/2023 7:26 pm
PM sent for the Transfer
Posted : 06/11/2023 8:31 pm
