Prophet front mech
[Closed] Prophet front mech
[#238424]
Does anyone know for what, if any, reason I can't run a regular front mech on a cannondale prophet?
Thanks.
Posted : 23/01/2009 7:35 pm
IIRC there's no room for the mech clamp on the seat tube (the swingarm pivot is in the way). The Prophet was designed for E-type front mechs.
Posted : 25/01/2009 1:46 pm
Just to close the topic; the Prophet will take an XTR M970 regular front mech with a standard triple chainset without compatability problems.
Posted : 08/02/2009 4:34 pm
can you post pix to show me please?
Posted : 08/02/2009 4:37 pm
Eh? You want me to go into my garage and take a photo of my front mech, publish the picture on the web and stick a link on here?
Bonkers.
Posted : 09/02/2009 12:19 pm
or
Posted : 21/02/2009 1:27 pm
racing_ralph - apply 1 second of thought and the answer should be obvious.
If not, look at your Prophet, remembering these two pictures, and imagine which one would fit and which one would be underneath the swing arm.
Posted : 21/02/2009 3:41 pm
i am thinking the bottom one but when the OP said "normal" xtr mech - normal is the usually the top pictured one - hence my question
Posted : 21/02/2009 3:54 pm
Forgive me for rekindling this thread, but I have more questions.
I'm running a two ring set up, the correct e-type front mech and a BB mounted Blackspire Stinger chain device. I have to run the mech flush to the BB shell and the stinger outboard of the mech, then the BB bearing. This is not ideal, the mech is too far inboard, the stinger too far outboard and I can't reverse them due to the shape of the pressing of the mech mount.
So, I want to try a normal front mech, ideally a double specific SLX one, but will I be able to mount it far enough down the down tube or will the boss for the e-type bolt interfere?
Anybody using a normal mech and a double set up?
Posted : 23/03/2009 10:51 am
Anyone?
Posted : 23/03/2009 2:28 pm
 dale
I too would like it spelled out dont mind admitting to stupidity
which xtr mech for tripple set up (in large letters please) slowly coz i realy am stupid and am sick of cleaning the E type
ralph did you understand?
Posted : 23/03/2009 3:07 pm
 Doug
I run a top swing mech. I had to cut a bit of the size adapter to get it to fit lower down the seattube. It works well enough with a double and bash if you move the chainline out a couple of mm which is what you should be doing anyway once you ditch the big ring.
Posted : 23/03/2009 5:29 pm
Just listening in as i've ordered a stinger but am now worried it won't fit.
The reason i got one was because i run a 2.5 tyre on the back and the mech can catch on the tyre when in the granny so i thought the stinger would tighten things up a bit as well as reduce the rattle.
Posted : 23/03/2009 5:44 pm
Here's the lowdown on e-type front mechs from Cannondale [url= http://www.cannondale.com/asset/iu_files/techcenter/2005_prophet_2005_front_derailleur_setup_guide_en.pdf ]clicky[/url] which shows that any 2005 or later mech needs to mount 1 spacer out from the bb shell. That would explain why I've had to bodge the cable tension and it's still a bit rattly at the extremes (eg middle ring and largest sprocket). The stinger should mount flush to the bb and act as the spacer, but the shape of the e-type mount fouls the 'boomerang' of the stinger (which it wouldn't do with a conventional bb spacer washer) so I've had to do it the wrong way round.
So, I'll take a closer look at the frame, an old top swing mech and my Dremel bits tonight, then probably take the plunge and order the SLX
Posted : 23/03/2009 6:07 pm
thanks dusty thats helpful and a spacer between the bb and frame may well solve my problem, though mines a 2006 and it didn't come with one?
Posted : 24/03/2009 11:47 am
FFS; Read my post
XTR M970
, the bottom one in the picture is not an M970 it's an M971 or something.
It works without any modification, bodge at all.
Posted : 25/03/2009 5:17 pm
Top swing double specific SLX fits, arguably sits about 3mm too high, but shifts a treat. No need for Dremel.
Posted : 26/03/2009 8:42 pm
So to summarise for a *triple* setup, the only non E-type mech known to work with is a top-swing M970 XTR?
These are 80 quid plus - has anyone tried an SLX/LX/XT top-swing and found it NOT to work? Because I might give it a go otherwise...
Posted : 06/04/2009 2:41 pm
Just in case anyone looks at this thread again, I just installed a top-swing, non-E-type SLX mech for my triple ring setup, and it works fine without any modification. I thought the E-type mounting boss on the frame would be in the way, but it's just low enough not to be an issue.
Posted : 02/07/2009 6:45 pm
