Proper old 7 speed ...
[Closed] Proper old 7 speed conundrum
[#11366112]
My neighbour has a 1995 something or other ATB with Acera X 7 speed triple drive trains, she's destroyed the rear mech and to be fair the rings and cassette look screwed, so no doubt the chain is - I suspect its original!
Where is the best place to get 7 speed replacements that fit?
Posted : 04/09/2020 2:15 pm
My first port of call would prob be SJS...
https://www.sjscycles.co.uk/cassettes-7-speed/
Posted : 04/09/2020 2:17 pm
 Bez
8 and most 9 speed stuff will work (except the cassette, of course). If you want 7 speed my first ports of call probably would be SJS Cycles or eBay.
Posted : 04/09/2020 2:19 pm
 Bez
LOL, clearly I took too long to type that 🙂
Posted : 04/09/2020 2:20 pm
Check it is a cassette and not a freewheel before buying anything.   SJS either way though.
Posted : 04/09/2020 2:51 pm
Rosebikes and Bike24 have a few 7 speed bits.
Posted : 04/09/2020 4:48 pm
Local bike shop?
Posted : 04/09/2020 5:23 pm
Ah, remember the days when (nearly) everything was compatible with (nearly) everything else? Good old days they were, and all of this was just fields...
Posted : 04/09/2020 5:27 pm
If the cassette, chain, rear mech and rings are shot, you're not really limited to 7 speed anymore. You might find a deal on some 9 speed stuff. After all, you're only shifter away.
I realise as I say that, there's a good chance the shifters are integrated to the brakes
Posted : 04/09/2020 5:54 pm
Amazon is also great if you know what you need
Posted : 04/09/2020 6:22 pm
If the cassette, chain, rear mech and rings are shot, you’re not really limited to 7 speed anymore. You might find a deal on some 9 speed stuff. After all, you’re only shifter away.
If it's a freehub and is spaced for 7 speed you won't fit an 8 speed on however a 9 will fit with a sprocket removed (did this for my sister in law), I found a 12t end sprocket to replace the 12t and 11t end so it doesn't look wrong.
Decathlon also do Microshift kit if you're working to a tight budget.
Posted : 04/09/2020 10:27 pm
