Pro2 free hub issue
[Closed] Pro2 free hub issue
[#12069655]
I ran an 11 speed cassette on a pro 2 evo no bothers.
Sold the wheels, and the chap that's got them runs 10 speed and he says although he can get the cassette on no probs he can't get the lock ring to engage and tighten.
I thought that a standard free hub will take 9/10/11 speed, there's no difference in the width of the cassette, am I right?
TIA
Posted : 11/10/2021 6:15 pm
Isnt there meant to be a spacer to go on at the back of the cassette 😕
Posted : 11/10/2021 6:19 pm
Dunno.. never ran 10 speed, can't remember if there was on on the 11!
The symptoms as described read like the lock ring won't engage, almost like its sticking out to far. if there was meant to be a spacer that isn't there id expect the lock ring to tighten but the cassette to be loose.
I will check though, thanks
Posted : 11/10/2021 6:26 pm
Dyna-ti is correct....to use a 10 speed on 11 speed hub you need a 2mm spacer..any lbs will have one for a couple of quid
The 2mm spacer goes on 1st then the cassette
Posted : 11/10/2021 9:05 pm
I've never had to run a spacer on a pro2 evo hub, I thought that is only required for backwards compatibility on Shimano 11spd road freehubs? Has he missed out a sprocket or one of the spacers between the sprocket?
For MTB:
Traditional (HG freehub) 9/10/11spd
XD for Sram 12spd
Microspline for Shimano 12spd
https://www.halowheels.com/which-type-of-freehub-do-i-have/
Posted : 12/10/2021 9:52 am
There's deffo a spacer needed behind a 10 speed cassette.
Posted : 12/10/2021 10:23 am
Thank you all again.. spacer it is!
Posted : 12/10/2021 11:17 am
Depends on the freehub, the pro 4 HG freehub and some pro ii HG ones - IIRC distinguished by colour - are road 11 speed compatible and will need a spacer for mountain 9-11 speed HG cassettes.
Posted : 12/10/2021 11:42 am
The other thing it could be is that the lock ring is incorrect.
It will have to be a 10sp lock ring, an 11sp wont work, it wont engage as he describes.
If he does not use a spacer, the sprockets will be loose.
If he uses the wrong lock ring, it wont engage.
I may be speaking from very recent experience and many swears.
Posted : 12/10/2021 11:47 am
