Pro2 bearings
[Closed] Pro2 bearings
[#4476412]
Need some new bearings in the rear hub..
Is it worth buying the proper hope parts (ukbikestore) or just big standard bearing factors jobbies?
Where do you buy yours?
Posted : 19/10/2012 9:09 pm
buy the propper ones
Posted : 19/10/2012 9:11 pm
 br
LBS, same price as elsewhere
Posted : 19/10/2012 9:15 pm
expensive bearings look nice but dont seem to last any longer in imho.
I got some on ebay sparepartsmonkey .cheep and lasting well so far !!?? could buy 2 or 3 sets from him for price of one hope branded set !
Posted : 19/10/2012 9:31 pm
 DT78
do you need any special tools to do the rear? mine need replacing too
Posted : 19/10/2012 9:38 pm
Got my last ones from a local bearing company, £6 or £7 each for SKF
A socket set ( plenty of sizes of socket to choose from )for tapping the new ones in and a screwdriver or punch to remove the old bearings oh and a hammer 😉 maybe some lube !!? sorry thats turning into a python scetch !! 😳
Posted : 19/10/2012 9:45 pm
DT78 - Member
Sockets of appropriate size (22mm-ish, one deep), a poking thing, and a course grade hammer.
Say his name and he will appear. 😉
Posted : 19/10/2012 9:57 pm
Oh yeah... One of mine has Kaesae's bearings in it, they're certainly no worse than many and might be better than most.
Posted : 19/10/2012 11:27 pm
Lbs sourced bearing shop ones the last time. Bearing shop next time.
Careful with the sockets. The proper tools make it easier -see crc under hub spares
Posted : 19/10/2012 11:30 pm
If you are going to be doing it regularly/have more than one set of hubs/have mates who might want to borrow them, then the set of tools certainly makes it a nice easy job.
http://www.thebikechain.co.uk/Hope-Pro-2-Tool-Kit-Complete-2011011107/
Posted : 19/10/2012 11:33 pm
I got Koyo bearings in mine and they seem to be lasting well. as I been testing/trying them before fitting to other hubs.
I would buy Hope bearings, as I do think they good vaule and good bearings.
Posted : 19/10/2012 11:39 pm
Ebay
Check the sizes (these might/ might not be the ones)
6802 2of 24 x 15 x 5 mm
6903 2of 30 x 17 x 7 mm
6902 1of 30 x 17 x 12 mm
Just put eg [i]6802 bearing[/i] in search in ebay or [i]15 24 5[/i]
http://www.cyclistno1.co.uk/features/maintenance/hope-pro-ii-rear-hub-service.htm
Posted : 20/10/2012 12:48 pm
Just replaced mine with stainless steel versions from Bearing Options. Fitted no problem.
Posted : 20/10/2012 12:58 pm
