Prime Dub BB
[Closed] Prime Dub BB
Just fitted a Prime Dub BB, one problem arose though. It doesn’t come with the 4.5mm outer spacer required, and the SRAM one from my previous BB doesn’t fit the Primr one! I don’t want to spend out on a SRAM spacer kit to find they don’t fit either... any ideas anyone? Seems strange to sell a Dub BB that isn’t compatible with the required spacers.
Posted : 08/07/2021 9:01 pm
Are you using it on a mountain bike? Prime very much a road brand
Posted : 08/07/2021 9:08 pm
Yes I am, I didn’t realise it was for road.
Posted : 08/07/2021 9:17 pm
It’s for road, not MTB.
Posted : 08/07/2021 9:55 pm
 Yak
I think I used some other random spacers I had to get it right. Probably less than on the sram one. It didn't last that long anyway, certainly less than a sram one.
Posted : 08/07/2021 10:53 pm
Yep stumbled across the Prime road bias issue myself recently with some adapters sized for road cranks that wasn't clear in the listing.
Posted : 08/07/2021 11:42 pm
 Yak
OP - if you can get a sram dub bb, then I would send the prime one back. If not then do what you can with bodge spacers from wherever.
Posted : 09/07/2021 10:21 am
Which type of dub is it?
Posted : 09/07/2021 10:36 am
If its a sram dub pressfit BB you need then you'll be waiting until autumn.
Posted : 09/07/2021 5:19 pm
I took it off, bought a Sram one. Lesson learnt, check carefully before purchase!
Posted : 09/07/2021 9:37 pm
Dub supplies are woefully low.
Buy every one you see lol
Posted : 09/07/2021 9:41 pm
Uberbike have hteir own brand in stock
https://www.uberbikecomponents.com/category/518/SRAM-DUB-Compatible-Bottom-Brackets
Posted : 09/07/2021 9:47 pm
Jonba those are external bearings so no use! It's the ones with internal bearings that are hard to source
Posted : 09/07/2021 10:57 pm
