Praxis M30 BB Tool
[Closed] Praxis M30 BB Tool
[#12127647]
Hi all,
Does anyone have a pair of these I could borrow or you may sell?
The BB is that came on my 2nd hand bike is starting to give in!
Cheers, Chris
https://www.tritoncycles.co.uk/frames-forks-c6/frame-fork-spares-c152/praxis-t47-m30-bottom-bracket-tool-p33713
Posted : 26/11/2021 3:06 pm
Pretty sure I do but away for the weekend. Furryboots are you?
Posted : 26/11/2021 4:17 pm
I have one near Tring if you are around that way
Posted : 26/11/2021 4:33 pm
Thanks guys, I should of said, i'm in Plymouth!
Posted : 26/11/2021 8:12 pm
I'm in Central Scotland, so probably a bit far away!
Posted : 27/11/2021 9:57 am
I've got the wrench version, and am near Exeter. If you're up this wsy anytime soon, happy to lend it.
Posted : 28/11/2021 9:12 am
Presume from this thread that they are a non-standard spline on these BBs? Was considering buying one of the cranks, but don't want to be stuck with something I can't fit cos tools are hard to find!
Posted : 28/11/2021 4:13 pm
The Praxis BB very slightly different to the Race Face BB30.
Same no. of teeth, but larger diameter by about 1-2mm. Annoying!
I've got RF turbine cinch cranks, and when that BB died I replaced with the Praxis one. Assumed it's be same tool. Nope!
I fitted originally with a big pipe wrench and a bit of old inner tube. Worked fine. But bought the proper tool for future use.
I'm not sure why there are 2 types of tools - socket type and wrench type. I assume they're the same fitting, but I've been proved wrong before!
Posted : 28/11/2021 5:04 pm
Cristof, I have one of the orange-handled ones pictured above and I’m only over in Saltash. You’re welcome to swing by if you want it.
Posted : 28/11/2021 9:11 pm
thanks @ajantom - from this I can presume Praxis cranks are compatible with other 30mm BBs then?
Such a minefield trying to move away from Splitmano cranks!
Posted : 29/11/2021 10:00 am
