Post mount bolts?
[Closed] Post mount bolts?
[#2857752]
What bolts do i need to run my Avid Elixirs on some post mount forks with a 180mm adapter?
I thought i had some, but i used them in some old forks and stripped the threads. The bolts may have been fine and it may have just been the forks that were knackered but i'd rather not risk it, so i'll just buy a new set that i know are the right size.
ta
Posted : 16/06/2011 12:57 pm
Are the newer elixers 180 setup - My avid juicy's are 185mm adapter and discs?
However is this what you are looking for?
http://www.amazon.co.uk/Avid-Caliper-mounting-hardware-Stainless/dp/B0050VEA3C
Posted : 16/06/2011 1:02 pm
Cheapest option is probably to measure the depth of the complete assembly, and aim to have a good 10mm extra to thread into the fork, then nip to your local engineering supplier. I'm pretty sure it'll be much less than the fiver quoted for a kit including washers etc. that you've already got.
Posted : 16/06/2011 7:25 pm
