Post mount adaptor.
[Closed] Post mount adaptor.
[#8122324]
Morning stw
Can anyone show me a link (preferably crc) to the adaptor I need to allow me to tun a 180mm rear disc. Frames an sb6c if that makes any difference? Currently running 160 and want to try an alp proof the bike.
Posted : 23/10/2016 6:24 am
Is the sb6c a post mount frame? Caliper straight onto the post mounts?
I've just done this myself and took the mount from the fork.
Posted : 23/10/2016 6:31 am
Yes it's post mount. Non of the adaptors say "rear" hence my confusion. Want one that comes with longer bolts if possible
Posted : 23/10/2016 6:33 am
Front or rear doesn't matter, just the numbers of that it is, and what it goes to.
My frame takes a 160mm rotor with no adaptor so I fitted a 160 to 180 post mount to post mount.
Two bolts fix the adaptor to the frame, two more fix the caliper to the mount.
Posted : 23/10/2016 6:39 am
Do some of them just have holes through and longer bolts? In my head this is a better solution.
Posted : 23/10/2016 6:41 am
I'm not sure they could without the use of cup and cone washers. Brake mount standards aren't radial so it's not just a case of raising th caliper up, there needs to be rotation to realign it.
I use Hope stuff, I can confirm theirs works and that it needs 4 bolts.
From the Hope stuff, it's the relatively new "L" mount that you need.
Posted : 23/10/2016 7:01 am
Onzadog, what you say makes complete sense, shimano/bike manufacturer however no, supply the other type (2 bolt) on most of the bikes I see, so are they wrong? I will be checking pad/rotor alignment later this morning on my son's bikes.
Posted : 23/10/2016 7:51 am
Seems the 4 bolt offset ones are only needed for 200mm+ rotors?
[url= http://http://www.chainreactioncycles.com/mobile/shimano-mount-adaptor-front-post-to-post/rp-prod13747 ]Pictures[/url]
Posted : 23/10/2016 8:05 am
Shimano 180 post mounts use longer bolts and a pair of cup and cone washers above the caliper. Sounds like they would be perfect for what you're after.
Posted : 23/10/2016 8:07 am
Which brakes? And do you have an adaptor on there now?
Shimano, you need one of these in 180 flavour assuming your rear end is 160 post mount: http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747
Guides or avids are a bit trickier - SRAM seem to assume we're all on 140mm rear discs now so if your rear end is 160 without an adapter you need the bolt kit for a 160mm rear disc. Confusing - but you just need to remember your going up 20mm. http://www.chainreactioncycles.com/avid-disc-brake-spacer-set-hardware/rp-prod108156
I don't personally like the longer bolts and big spacers but the sram 20mm adapter is oem only, you can't buy them off the shelf.
Edit: Planet X have the sram/avid ones you need http://www.planetx.co.uk/i/q/BSAVPPBM/avid-post-to-post-brake-adaptor
Posted : 23/10/2016 10:54 am
