Polishing a turd?.....
[Closed] Polishing a turd?....
[#7991090]
Hi,
I've been riding more challenging stuff recently and my fork seems to be struggling a bit.
It's a 26" 2012 Fox 36 TALAS RLC.
I'm wondering if anyone here has put different internals in their forks, and did it make a difference?
I'm thinking of FLOAT and 150mm but can I fit any more,modern internals?
Thanks si
Posted : 09/08/2016 9:20 pm
Difficult to polish, but easy to roll in glitter. (on a more useful note - black box RS revelation forks are IMO ACE and now old hat)
Posted : 09/08/2016 9:22 pm
You need to talk to mojo to find out what is possible and what the costs would be. Also have you had the future serviced recently?
Wally, a set of revs will feel like a noodle after 36s (though agree the black box dampers were nice).
Posted : 09/08/2016 9:56 pm
I now ride SIDS, noodle doodle dandy is my middle name. LoCo is the expert here, IMO. Ask him.
Posted : 09/08/2016 10:01 pm
26" of travel or wheel size? Former will be an issue even for 36s, the latter won't.
What travel does it have? Is it adjustable and do you adjust it?
Posted : 09/08/2016 11:03 pm
Had this last year and the newer better float stuff wouldn't fit so just got a vanilla conversion done by tf and it's now ace
Posted : 10/08/2016 12:30 am
Avalanche damper and a float conversion on the air spring side - job done.
Posted : 10/08/2016 5:35 am
My opinions...
TALAS was never quite right. Pandering after the spring crowd 😉 The Linear Part means it needs a lot more Low Speed compression for set up and good high speed R2C2 is the only damper worth it for TALAS. The Float is a lot better, especially if you never use the travel adjust.
As Onzadog has said a float conversion (replace the Talas part with a simple air spring would by my first move. After that if you want more set up then Avalanche. It gets a bit pricy as your paying in USD and it's going to be hit for import. Fitting however is easy so long as you can do a lowers service and read/follow instructions.
Posted : 10/08/2016 5:40 am
Thanks for the replies.
I think the FLOAT conversion will,be my first port of call, along with a drop to 150mm. The Five with 160mm is a pig to climb on.
I am interested in the avalanche damper but I can't find many reviews. Is it really worth it?
Posted : 12/08/2016 9:02 pm
