I've just tried to fit my PNW post and Loam lever to my new bike...the Rockshox Oneloc lockout remote seems to be freakishly bulky so I can't work out how to fit the Loam lever either inboard or outboard of it!
The only way I think I could bodge it (after noticing the Oneloc comes in a 'left-above' option for a piffling £54) is to flip my left-below into a right-above position, but it makes a mess of the cable routing and would be crushed as soon as I put any luggage on the bars.
Not sure it would fit with an ispec mount either? Any pics or suggestions appreciated 🙂
Can the Loam Lever go on the right-above position?
The alternative is a 2x lever. PNW do one called the Puget or Brand x do a cheaper one.
It would actually, thanks. Not sure why I didn't think of that! It's not the prettiest option but will do for now until someone points me to some obscure matchmaker piggyback ispec mount 🙂
The cable routing is better than running the Oneloc on the right.
Apologies if I am stating the obvious. Did you try each position? The loam has 2 different positions if you need a shorter or longer reach.
Yeh unfortunately the Oneloc prevents the Loam lever going anywhere near it!
I'll probably the Brand X 2x lever at some point.
