Plus 10mm rear disc...
[Closed] Plus 10mm rear disc brake adaptor. Do they exist?
I've got a Hope AM SP4 4 bolt disc rear hub in a Norco torrent frame.
The disc is 180mm and the caliper is IS held on with a +20mm hope adaptor, which i assumed is what would work out correctly.
But it doesn't ๐Ÿ˜ฅ
With the adaptor fitted the pads only bite with about half there depth onto the disc.
Remove the adaptor and the caliper doesn't fit at all.
So i assume i need something somewhere in between, but what, if anything is available?
Ta.
Posted : 29/05/2011 12:05 pm
What caliper?
Posted : 29/05/2011 12:18 pm
Depending on the year, it used Avid 160 rears so 180 should work with a +20 mm adaptor. This is where a picture of the set up may help. Is the +20 an IS to IS? Or have you tired to do away Avid adaptor at the same time? If so, this could be the problem.
Posted : 29/05/2011 1:24 pm
Its a Hope xc 4 caliper No3
I've just twigged, it might be the caliper thats the issue.
Posted : 29/05/2011 4:06 pm
That's why I asked, XC4 use a different sized disc to the modern stuff, No.3 on the rear was for a 165 rotor if I remember correctly.Think my mate may even have a pair tucked in his box of spares, will ask tonight if you're interested.
Posted : 29/05/2011 5:26 pm
actually it seems to be a 150mm rotor, also got a 130 and 170 in his box,will pass on his details if you e-mail me.
Edit-just noticed you're in S Wales too, Cardiff area by any chance?
Posted : 29/05/2011 7:24 pm
Thanks for the offer Coatesy.
My disc is a rather unusual 4 bolt item, a right pig to get hold of.
I'm halfway between Swansea and Cardiff.
Anyway..fixed it now. Please don't ask what i'd done wrong its far too embaressing
Posted : 29/05/2011 8:06 pm
You have to tell us if it's an easy fix or very silly. It's the rules of forum help.
Posted : 04/06/2011 8:32 am
I suspected the mount being upside down, but didn't want to cause embarrasment ๐Ÿ™‚
Posted : 04/06/2011 5:40 pm
That would have been my guess but it's always nice to know. ๐Ÿ˜€
Posted : 04/06/2011 6:26 pm
