Please help me iden...
[Closed] Please help me identify my Hope hub!
Bought used last year so unsure of any specifics.
Sorry for the link - don't know how to put pics on here ๐Ÿ˜ณ
http://s959.photobucket.com/user/rascal011/library/?sort=3&page=1
Want to run a 12mm bolt-through axle instead of current QR. Is it easy?
Cheers!
Posted : 30/12/2014 4:39 pm
Looks to be Pro 2 or Pro 2 evo, not sure how you identify the difference, and the E-Y marking on the hub isn't helping any either.
[EDIT: Removed quote, after looking at tech doc, as it seemed nonsense]
To be the most obvious difference is that the freehub bearings are 15mm on the Pro2 and 17mm on the Pro 2 evo
Not a huge amount of help, other than to confirm you will be able to convert it, with the right kit. Doing the conversion isn't difficult, large hammer and a couple of sockets will get it done (search youtube for a guide)
Posted : 30/12/2014 4:51 pm
Looks like a Hope Pro 2 (not Evo) to me, which means 12mm x 135mm axle is available, you need a new Axle and end caps.
[url= http://www.chainreactioncycles.com/hope-pro-2-conversion-kit-rear-12mmthru/rp-prod21849 ]As available here (other sources available)[/url]
Posted : 30/12/2014 4:52 pm
I think (someone back (this up please) that if you pull one end cap off an Evo you'll be able to slide the 12mm axle (Maxle etc) partially in, the Pro2 you won't as you need a dedicated 12mm Hope hub axle
Posted : 30/12/2014 5:06 pm
Ask Hope, they're usually very helpful.
Posted : 30/12/2014 5:11 pm
Thanks - I will ask Hope as I'm quite confused as to exactly what I need to go from QR to 12mm bolt through now ๐Ÿ™„
Posted : 30/12/2014 5:16 pm
Ar%e - emailed Hope but no one's home until Jan 5th ๐Ÿ˜ฅ
Posted : 30/12/2014 5:42 pm
Looks like a pro 2 (non evo)
And Rockthree is correct, pull an end cap off and check
Posted : 30/12/2014 5:48 pm
 jonk
If its an evo you just change the end caps if not new axle
Posted : 30/12/2014 5:49 pm
 gee
That's a Pro2. The Evo ones say Evo on the hub shell, at least mine does.
And yes, as above you'll need a new axle and end cap kit.
Posted : 30/12/2014 6:23 pm
Had a look on Youtube - you can pull the freehub body off with a twist - I can't seem to on mine.
The current end caps don't come off either - could be doing it wrong though!
It's def not an Evo hub - too old.
Posted : 30/12/2014 10:00 pm
The end caps can be barstards, though it's only an inner o-ring that's causing the friction, try using two screw drivers to prise them off or molegrips wiggled up & down while pulling on it. The freehub might also be sticky, I throw part of a cassette & locknut on the hub (done up finger tight), then while supporting the wheel with the freehub facing down, bash the back of the cassette through the spokes with a hammer & dowel (other ways are available) until it pops off
Posted : 30/12/2014 10:09 pm
certainly looks like a pro2. although every one I've ever seen has had pro2 etched onto it.
Posted : 30/12/2014 11:19 pm
Deffo a pro 2 but could the lack of logo possibly make it from their 'Hope Hoops' wheelsets ?
I'd wrap something around the end spacer to protect it should you need to pry it off. Fabric elastoplast is a good choice.
Posted : 31/12/2014 2:04 am
Its absolutely not an Evo, all Evo's have an stamp on them, it's ether a Bulb or a Pro 2, some Pro 2's didnt have the stamp on them
Posted : 31/12/2014 7:07 am
Looks like a pro2 to me (none evo) if it's for 142 x 12 you will need the
X12 kit.not the one above. X12 comes with different end caps.
Posted : 31/12/2014 8:17 am
