Please help
[Closed] Please help
 baza
On building up pace 405 what size and type ( intergated ? ) headset do I need, getting desperate.
Posted : 13/01/2010 10:29 am
from the 2010 brochure:
Headset (Semi-Integrated 28.6) 44mm cup
HTH
Posted : 13/01/2010 10:33 am
semi integrated - basically like a normal headset but the cups sit inside the frame instead of outside it.
You can identify semi-integrated because they'll have a lip at the top / bottom - eg: (called zero stack)
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=7389 [/url]
or this one [url] http://www.chainreactioncycles.com/Models.aspx?ModelID=15888 [/url]
or this Hope one:
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=18084 [/url]
while this is the [u][b]wrong[/b][/u] (integrated/hidden) type - no cups - the bearing sit directly in the frame
Posted : 13/01/2010 10:35 am
