Plastic tube for bl...
[Closed] Plastic tube for bleeding Hope brakes...?
[#633665]
Trying to find the correct diameter clear tubing to bleed my M4 brakes...any suggestions? I don't really fancy paying £30+ for the official bleed kit. Cheers.
Posted : 15/06/2009 10:10 am
Windscreen washer tube from halfords or a cheap bleed kit, aquarium air tube from a pet shop.
Posted : 15/06/2009 10:13 am
Quick blag at your friendly local bike shop?
Posted : 15/06/2009 10:17 am
Home brew kit from hardware shop
Posted : 15/06/2009 10:28 am
windscreen washer tubing looks suitably cheap & simple. Anyone know the diameter required for Hope stuff? I know it's different to Avid as my Juicy bleed kit tube is too small. Cheers.
Check the garage at your in-law's place - there's a blead kit in there that I left behind. - It's the genuine Hope deal, in a hope brake rotor box.
The pipe from the sump bottle doobry is 'adjusted' to fit a track pump so you can pressure the **** out of it...
Stupid me should have brought it with me, as a bleed kit over here is well expensive.
Posted : 19/06/2009 3:26 am
B+Q sell various dia clear tubing by the mtr.
Posted : 19/06/2009 7:24 am
I bought some windscreen washer tubing from halfrauds yesterday( I got the largest size), it didn't fit my gf's mono minis. So I boiled it in some water, then streched it down a piece of metal rod then melted the end so it stayed that size. It worked a treat.
Posted : 19/06/2009 8:31 am
 drew
Our local motor parts store sells clear tubing by the foot so its not expensive to try a couple of different sizes out. check out the ones near you.
Posted : 19/06/2009 8:36 am
Maplins sell an educational hydraulics kit that includes tubing and a few syringes which is ideal for brake bleeding purposes.
Posted : 19/06/2009 8:52 am
Hi matey, good to see you on here. Thanks for the tip...I'll nip up there later & see if I can dig it out. If u need it I can always send it over...?
Posted : 19/06/2009 9:05 am
+1
I just went to a home brewing shop to get some. Pence. Various syringes left over for child's illness and sorted...oh and a jam jar.
Posted : 19/06/2009 9:43 am
old camelback tube?
i can ecommend the bleed kit though - makes the whole job way easier with the pressure going in. The only bit that you couldn't knock up yourself is the bleed top cap for the reservoir though - so £30 is a bit steep, but if there's one sitting there waiting for you then i'd get that rather than faffing about.
Posted : 19/06/2009 9:51 am
Ah, that might a good option. have a look and if it's serviceable feel free to use and perhaps we'll sort something out in the near future.
Been sat in there for a few years now though eh...
Posted : 20/06/2009 3:32 pm
Homebase/B&Q/Wickes etc all sell lengths of hose/rope/chain etc by the metre.
I get mine from Homebase, for £1 a metre.
Bargain.
Posted : 20/06/2009 3:39 pm
 StuE
Large syringe from chemist (50p) had a bit of tube in the garage the fit the syringe but not the bleed nipple, heated end of pipe with a lighter, pushed it on bleed nipple now fits a treat, its much easier bleeding from the bottom up, I use a kids plastic bucket to catch the bit of overflow, I do remove the wheel and pads so they don't get contaminated.
Posted : 20/06/2009 7:11 pm
