Pinnacle Arkose Thr...
Pinnacle Arkose Three (jameso to the forum please)
RD, no, it's the same frame for 700 and 650. Still quite a low frame, BB drop etc.
Posted : 23/10/2019 3:17 am
I have a 2018 Arkose X. The rear hub was changed by Evans at the 6 week service from a cone and cup to a cartridge hub (Novatec D482TSBT) because they had found a fault with it.
The front hub is now getting rough (doesn't improve after servicing) and I would like to change it to a cartridge type hub, with a similar spec to the Novatec D482TSBT on the rear. Any recommendations? Should I just get a new wheel or swap the hub? I'm happy with rims on the bike and I'd prefer the wheels to match. How much would it cost to build up a wheel?
Posted : 24/10/2019 1:48 pm
RD, no, it’s the same frame for 700 and 650. Still quite a low frame, BB drop etc.
Cheers, hoping to sit her on one soon.
Posted : 24/10/2019 1:59 pm
I see Evans sell a Pinnacle Adventure Road Disc Wheelset (EV324477) for £250. These wheels have Novatec D791SB (front) and D792SB (rear) hubs which I understand were fitted on the Arkose 4 (2018) bikes. I wonder why the Evans store put a D482TSBT hub on my Arkose X rather than the D792SB?
Posted : 25/10/2019 11:09 am
I have an Arkose D2 that is 4 months old. It has developed an annoying click from BB, and a creak from the rear hub/cassette when climbing out of saddle in biggest sprocket.
Is the clicking BB a sign that the bearings are failing? There isn't any play, but it doesn't seem right.
Anybody else had issues with the FSA BB?
I guess I could take it back to the shop but it might be hard to replicate in the stand
Posted : 27/10/2019 7:08 pm
check the pedal threads, it could be something as simple as the threads being dry and needing a coating of anti seize. but yes, FSA doesn't have a good reputation of the seals on their bearings on any component
Posted : 27/10/2019 7:14 pm
Hmm, I have some new pedals that I am due to fit this week, so will be easy to rule that out.
Posted : 28/10/2019 8:52 am
@jameso
Would the dynamo front wheel be strong enough for a tandem as well as the Arkose? Think I can kill 2 birds with a single stone here...
Posted : 28/10/2019 10:54 am
Good Q, I'm not sure tbh. Would have to say no to be safe, it's a machine built 32h.. not specified for that use
Posted : 28/10/2019 8:32 pm
Cheers! Will stick to plan A!
Posted : 29/10/2019 5:03 am
I've got a 2017 Neon, which I think is pretty similar to the Arkose of that year.
Do 40mm tyres fit OK for you guys? Planning a long gravel ride next year & need the extra cush/grip.
Posted : 04/11/2019 11:52 am
Hi folks, Pinnacle Arkose 4, 2018 and would also like to do a hub service. I see Mike DIY'd it. Care to share how difficult a job it was and which bearing pack is the right one? @mikertroid @jameso
cheers
Posted : 04/11/2019 10:18 pm
Picked up a immaculate second hand 2018 Arkose 2 this weekend. Looking forward to getting to know the bike.
Can't work out how to post an Instagram shot to show off the lovely colour.
Posted : 18/11/2019 9:50 pm
Hi folks, Pinnacle Arkose 4, 2018 and would also like to do a hub service. I see Mike DIY’d it. Care to share how difficult a job it was and which bearing pack is the right one? @mikertroid@jameso
I can barely recall doing it, so it wasn't hard.... it was the front hub, so it was a case of gently drifting the bearings out from the opposite side and replacing with the new bearings. Less than 10 minutes IIRC.
Posted : 19/11/2019 9:31 am
 lcj
Thanks for the feedback earlier, Jameso.
Medium Arkose X ordered today - the sale price and C2W discounts made it too good to refuse!
Posted : 20/11/2019 6:34 pm
The bearings were 6902s
Posted : 20/11/2019 10:55 pm
After some help.
I've got a 2017 Arkose with Novatec D482TSBT hubs.
I can't find a service guide or tutorial for this hub and need to replace the bearings.
Anyone able to send me a link?
This hub does not seem to be listed on the Novatec website.
I have checked it's the correct code.
Posted : 25/11/2019 3:23 pm
Come on you excitable Arkose owners, someone must know something?
I've exchanged emails with Novatec and no tutorials or help with process to change bearings on this hub.
For info it's the hub with nuts that screw on either end of the spindle not Allen keys in the spindle.
I can remove the non drive nuts and bearing seal but do not know what to do next e.g. bash the spindle thru (unlikely with the freehub still attacked) remove the freehub (does it just pull off like a Hope hub). Do i remove driveside nuts by clamping spindle on non driveside?
Help would be appreciated.
Posted : 26/11/2019 4:30 pm
Hi Karlp. I think I know now why Evans put the Novatec D482TSBT hub on my Arkose X (2018) -they had one spare from the 2017 bikes.... I can't tell you how to change the cartridge bearings sorry - I would get my lbs to do that. Would you mind telling me which hub is on the front wheel of your 2017 Arkose please and is it a thru axle? I eventually want to change mine to a cartridge type hub. Cheers si
wildsi
Member
The front hub is now getting rough (doesn’t improve after servicing) and I would like to change it to a cartridge type hub, with a similar spec to the Novatec D482TSBT on the rear. Any recommendations? Should I just get a new wheel or swap the hub? I’m happy with rims on the bike and I’d prefer the wheels to match. How much would it cost to build up a wheel?
Posted 1 month ago
wildsi
Member
Posted 1 month ago
Posted : 27/11/2019 10:58 pm
WildSI my font hub is a Novatec D791SB which is bolt thru.
I'm taking rear to Evans today in the hope one of the mechanics might enlighten me on how to remove freehub etc.
I'm happy to pay them to do it but I want to be able to do it myself too.
Posted : 28/11/2019 8:41 am
@Karlp, @Wildsi, D482TSBT - I think - and I've not pulled one apart myself, and tbh though the hubs are good we're speccing less Novatec in future simply because the service info from them isn't clear between myriad variants/can be hard to get hold of/etc - I think it's the same process as this, this video just shows the non-disc version
Posted : 28/11/2019 9:57 am
James not an arkose question but a question re the new Ramin - looks good on website but cant find a geomentry chart anywhere, do you have one or have the fidgures for a medium?
reach stack head angle seat angle and is head angle measured with fork sag?
thanks
Posted : 28/11/2019 3:23 pm
Geo chart for the Ramin to be uploaded asap.
Med -
450mm seat tube
470mm reach
650mm stack
805mm F-C
65 HTA static 130mm fork
75 STA
ramin
Posted : 28/11/2019 3:38 pm
Jameso, it's not same as that video.
Understood your point re Novatech as the info I got from them was misleading.
However I chatted to an Evans mechanic and below is how I did it for the d482tsbt rear hub.
1. Remove cassette.
2. Remove both sets of endcaps (keep in order or take photos etc.). This needs spanners not allen keys. For me the non driveside came off easy and I needed to clamp in order to remove driveside.
3. With the freehub in place bash the axle thru from the non driveside. This removes the driveside bearing.
4. Remove the driveside bearing from the axle.
5. Spin the axle round and then use it to remove the non driveside bearing I.e. insert thru hub and give it a bash.
6. Press the new driveside bearing into place.
7. Insert the axle and press the new non driveside bearing into place.
8. Replace the endcaps and the casette.
Caveat the above should be correct but drafted after the fact not done from notes made at the time!
Posted : 28/11/2019 4:55 pm
Hi, after some info really, currently riding a 2016 revolt and have been looking to upgrade for a while. The Arkose X that is currently being offered by Evans at just over £1000 has caught my eye at such a good discount.
However unsure about the 650b wheels on a drop bar ride . My mtb is 650b my revolt is 700c is there anything noticeable with the dirlfferent wheel size. I quite like the idea that you can interchange to 700c if you require. Also my revolt is 3 x 9 how does a 1 x 11 compare when commuting etc etc. Thank you for your time.
Posted : 28/11/2019 9:15 pm
Thanks karlp and jameso. I'll probably just change the front hub to the Novatec D791SB. SPACYCLES are selling one for £30 ( https://www.spacycles.co.uk/m2b0s117p3850/NOVATEC-D791SB-Front-Hub). Would this be the correct one for the Arkose X 2018? Which hubs will be specced in the future if you are moving away from Novatec?
Posted : 28/11/2019 9:16 pm
townydc My 2018 Arkose X has 1X10 Deore gearing and it is spot on for commuting. The 1X11 will be wider still.
Posted : 28/11/2019 9:20 pm
Thanks wildsi, it's a very tempting offer.
Posted : 28/11/2019 10:19 pm
it’s not same as that video
Darn, sorry. And there's my frustration, code number is generally the hub tech/type. But here it's quite different. I need to go on the Novatec intensive product info and code logic course, clearly. If there is one : )
I’ll probably just change the front hub to the Novatec D791SB. SPACYCLES are selling one for £30 ( https://www.spacycles.co.uk/m2b0s117p3850/NOVATEC-D791SB-Front-Hub). Would this be the correct one for the Arkose X 2018?
It talks about conversion to 15mm, but the Arkose fork 2018>current is 12mm. We mosly use hubs from KT, Novatec and Shimano. Used to use some from Chosen. Future spec will be based more on service info and spares commonality for easier stocking at our end, I want this to be easier for everyone. I'd like to use more Shimano but the cup and cone spec is a negative for some, plus they don't cover all the options as well as the more extensive (but occasionally random or scattergun) OE suppliers in Taiwan.
Posted : 29/11/2019 4:31 pm
Liking the look of the Ramin....
My son is riding my '15 one and in not likely to get out back off him..... ..😎
Posted : 29/11/2019 4:43 pm
Do you think the Arkose D3 will be discounted anytime soon?
Tempted to order now but knowing my luck it will be reduced in price soon after i place my order.
Posted : 29/11/2019 4:59 pm
^ if not discounted for BF I doubt it. Not a plan I've heard discussed either. They're selling through quickly and orders are placed into spring now so I expect there's no reason to discount only to be out of stock for a while due to a higher rate of sale. So, no - but they have refunded the difference in the past when what you're concerned about has happened.
Posted : 29/11/2019 5:28 pm
Thanks Jameso. Its not straight forward is it! Have you experience of Hope hubs. Spa cycles are have this one for £65 ( https://www.spacycles.co.uk/m2b0s117p4078/HOPE-Pro-4-Front-Hub). Would it be suitable for the Arkose X (2018) front wheel?
Posted : 30/11/2019 10:08 am
Thanks Jameso. At full price it is probably still the bike I like best so will probably go for it.
Posted : 30/11/2019 10:36 am
The 12mm option will, yes. If it can be adapted to a 100x12mm spec, it'll fit your Arkose fork which is 100x12mm. The thru-axle you have will work with a new hub of that standard.
Posted : 30/11/2019 1:33 pm
What's max tyre size on 2018 arkose 4,??
Posted : 30/11/2019 9:52 pm
Finally ordered an Arkose X in the Evans Black Friday deal. Also got an extra 8% off with instant vouchers through my work rewards scheme. Blinding deal. Hopefully picking up from the Bristol store later this week. Can't wait to try 650b on the local lanes and tracks...
Posted : 01/12/2019 8:36 pm
Thanks for your help. I think I will splash out and get the Hope hub
Posted : 02/12/2019 9:00 am
Morning all, I think I've gone blind trawling this lot, so can anyone help with a hub question? I have a 2015 Arkose which has gloss black Joytech (?) cup and cone hubs, with as far as I can see, no identifying marks. The freehub has gone on the rear - any pointers on to replacement? Evans used to stock some, but no longer offer one. I can always just get a Deore hub to replace it, but would rather not rebuild the wheel if I can avoid it - though it might give me a excuse to try my hand a wheel building. The bike was bought second hand and had done very few miles before I got it, but think what little grease was in the rear hub and probably the freehub got washed out going through the floods in Cheshire recently!
Posted : 03/12/2019 10:32 am
Arkose 1 2015 Joytech D342RCC EV264869
Arkose 2 2015 Joytech D342RCC EV264869
Hi Martin, this is the info for the 2 Arkoses that used Joytechs in 2015 but the freehubs are out of stock now.Joytech D142DSE uses the same freehub if that helps locate one anywhere else? tbh I'd pop a Shimano in there or a Shimano-hubbed wheelset.
Posted : 03/12/2019 2:53 pm
Cheers jameso - ideally wanting just to put a freehub in to keep them going until I can afford a decent wheelset, so will see what I can come up with - thanks for the super quick answer!
Posted : 03/12/2019 3:17 pm
I have a 2017 Arkose 4 frame. Id like to fit it with 650b wheels and im wondering how large a 650b tire will fit the frame and how using 650b wheels will impact BB height. Thanks.
jrmac
Posted : 03/12/2019 7:20 pm
Picked up the new Arkose X yesterday...just waiting on some wider tape to convert the Byways to tubeless, but the bike seemed comfier on my local tracks with 650b tyres, even at slightly higher pressures to avoid pinchflats...need to get some knobblier 650b tyres too, as the slick Byways were pretty skittish in mud (though highly entertaining!)
https://i.postimg.cc/vHB1ZPgC/20191207-145921.jp g" target="_blank">https://i.postimg.cc/vHB1ZPgC/20191207-145921.jp g"/> [/img][/url]" alt="null" />
[url= https://i.postimg.cc/yYbDgF0x/20191207-132507.jp g" target="_blank">https://i.postimg.cc/yYbDgF0x/20191207-132507.jp g"/> [/img][/url]
Posted : 08/12/2019 9:20 am
Hi jameso do you have any info regarding Arkose and Neon models for 2020, or will the existing ones be kept on until next year? I appreciate the 2019 models were somewhat delayed until March/April.
Thanks
Posted : 14/12/2019 1:02 pm
Hi @jameso - Had all the bits nicked off my Arkose 4 so looking at getting an Arkose X as a replacement. Did the geo change at all? I had a 46T chainring on my 4, will the X still clear that (in 1x). Thanks!
Posted : 14/12/2019 6:57 pm
Page 34 / 40
