Pike seal dimension...
Pike seal dimensions
 LAT
[#13535647]
I have a formula fork, but pike seals are much easier to find. So im hoping that someone will know the dimensions of pike seals, or have one that they could measure?
the dimensions I’m interested in is the diameters and the depth below the flange of the part of the seal that is pressed into the lowers. The inside diameter of the wiper lip is probably a good thing to check, too.
many thanks in advance for all assistance.
Posted : 21/05/2026 10:06 pm
I have some seals from a 2016 pike
External is 45.3mm
Internal 35mm
Internal of sealing lip 33mm
Total hight 12mm
Hight of ribbed section 8.2mm
Posted : 25/05/2026 12:31 pm
I bought some 35mm SKF green seals meant for RS forks for my Selva C but they were too big. Outer part of the seal ripped when I tried to install them, I even had kept them in a fridge and used proper seal install tool.
Posted : 25/05/2026 5:30 pm
Do Elro Distribution not have what you need? Or are you not UK based?
Posted : 25/05/2026 7:24 pm
