Pike rct3 charger d...
[Closed] Pike rct3 charger damper problems
[#10648829]
I'm.stuck with a problem and would like some help please.
Rs pikes rct3 160/27.5
It seems that the charger damper when out of the stanchions can be compressed fully but when placed in the stanchions only gives 2/3's of travel as the charger bladder is pushing against the inside of the stanchion tube. I've wound the HSC off and the lsc but still have this problems.
Any ideas??
Posted : 31/05/2019 8:08 pm
Bladder is over filled, often caused by oil ingestion via the lower seal head.
There is an updated lower seal head
Overfilling the lower oil will result in lower oil ingestion into the bladder
If you keep riding the bladder will split/burst.
I would suggest a full service, if you want a short term fix I would let the excess oil out the bleed port.
Posted : 31/05/2019 9:08 pm
Thanks. Bladders burst now so I'll know for next time.
Posted : 31/05/2019 9:21 pm
Pike full seal kit should come with a new bladder, if its like the some of the Lyriks and the bladder is not available separability, only as an assembly I would get a WSS bladder.
Posted : 31/05/2019 10:00 pm
Are these bladder dampers generally unreliable then? Looking at some take off Revs as s potential purchase that had the RCT3 damper upgrade (and travel increase to 160).
Posted : 31/05/2019 10:46 pm
No bladders are usually pretty good as long as lowers not massively overfilled and they’re serviced around the specified time with replacement bladder & seal heads etc
Posted : 31/05/2019 11:38 pm
This is the second one I've had go pop
Posted : 01/06/2019 12:00 pm
