Hi
just changed my Pike airspring to the latest 2019 version. Just checking - the spring that came out had a metal washer and a spring washer between the piston and the seal head, that the new one doesn't. I assume these aren't meant to go back in with the new spring?
thanks
Posted : 27/10/2018 11:24 am
Correct, just in case you haven't, watch this..
Posted : 27/10/2018 11:34 am
cheers - yes, I did watch that, so was 99% sure they didn't go back in
am I right in thinking you can change travel just by changing the air spring?
Posted : 27/10/2018 11:48 am
Yep, the pike can only go up to 160 though.
Posted : 27/10/2018 1:46 pm
