@j273 apparently 20% is about right for a rochshox air fork
@bluearsedfly not taken my top cap off running no tokens at the mo
tymbian - Member
Fighting weight with camelbak 95 - 100 kgs. Recommended pressures around 95psi. but this was so harsh.Running 70 psi with 5 clicks on the compression...still not convinced about the small bump compliance...they don't feel very plush if you ask me.
I'm around 87kg with all the gear and 50psi with full open LSC.
Try running with full open compression and see how that feels? Then try with -5 drops in PSI until you get 20% sag.
@ Northwind and cruzcampo Just found [url= http://www.ebay.co.uk/itm/Laser-Racer-Axle-Wrench-17mm-24mm-Motorcycle-Tools-WorkShop-Garage-/330734665352?pt=UK_Home_Garden_PowerTools_SM&hash=item4d01527e88 ]these[/url] on ebay.
Might do the job?
Why do people get hung up on using full travel all the time, it should be how the fork feels. I'm 190lbs and running about 85psi 20% sag. The people running these forks at 10 to 20 psi below the recommended pressure must be mincers!
doodes - this is ideal for removing the top cap. stealth black too
[url= http://www.ebay.co.uk/itm/24mm-Shallow-Oil-Filter-Socket-BMW-series-5-7-/250658397773?ssPageName=ADME:L:OC:GB:3160 ]http://www.ebay.co.uk/itm/24mm-Shallow-Oil-Filter-Socket-BMW-series-5-7-/250658397773?ssPageName=ADME:L:OC:GB:3160[/url]
