I'm watching for bargains on parts for my new build but have some questions. The plan is to build it up 1x10 with hope NW retainer plus a 40t rear cog.....but buy xt 2x10 so if my dodgy knees complain I can retro fit that.
Can I lean on use forums expertise once more...
I guess I need a shadow plus rear derailleur to give me the clutch retaining action?
I've bought the shimano hope 40t cog so am I stuck with shimano cassettes now (as opposed to SRAM?)
Do I have to use shimano chains on his set up or can I use SRAM?
Do xtr 10spd shifters work with xt 10 spd rear derailleur?
Is the I spec b specification to integrate with shimano brakes ? I have hope so am guessing I need bar mount shifter?
Many thanks
Yes, or SRAM Type 2I guess I need a shadow plus rear derailleur to give me the clutch retaining action?
Don't know but I suspect the clue is in the name.I've bought the shimano hope 40t cog so am I stuck with shimano cassettes now (as opposed to SRAM?)
You can use either.Do I have to use shimano chains on this set up or can I use SRAM?
YesDo xtr 10spd shifters work with xt 10 spd rear derailleur?
Don't know.Is the I spec b specification to integrate with shimano brakes ? I have hope so am guessing I need bar mount shifter?
Thanks. Re.the hope 40t I didn't know if the "shimano" referred to the compatibility with the rest of the cassette or the free hub body type.
Any thoughts on this I spec b malarkey anyone?
Edit and also what's the "normal"crank length? I170 or 175? Ive never specified this myself on a bike before.
The freehub body is pretty standard until you go 11 speed or back to 7 speed so I think it refers to the cassette construction. NB, just to confirm - 10sp SRAM/Shimano rear mechs/shifters aren't interchangable - but you knew that. 8)
Newer Hopes (Tech 3) will mate to an I-Spec shifter, but you'd need to check about Spec A/B
Ok great info ta.
Looking at ribble for a good price on the group set but they've specified a RD "sgs direct mount"
CRC just talk about m786 either medium or long cage....?
